There's no way to screw GPU into case.
I'd say you're fine without the screw then. Most motherboards clip lock the GPU in place, hopefully yours does too. If not,
you'll just have to be aware that it's not secure anytime you plug in or unplug a monitor so you don't unseat the GPU.
You don't have a place like this?
IkwOXROvTCXf5lrK.medium
Take a picture of the area for us? I think we're all genuinely intrigued.
In terms of fixing this, there is nothing stopping you matching the thread and drilling a hole. Just bear in mind this will be irreversible should you misjudge it.
That being said, It is a drastic measure and as mentioned above, All cases should come with holes for attaching these cards. It is very strange that one should not
Regards
