Question Thermal compound on CPU pin
Nov 25, 2019
21
I managed to get a tiny bit of thermal compound on one of the pins, underneath the CPU ( barely visible ). As it was so little and was not effecting the placement of the CPU into the motherboard, I decided to put it in anyways. Now thinking about it I feel I might of made a mistake. Have I?
I would not worry about it now...any tiny transfer from the pin into the socket has already occurred, so, concern, over it now , even if largely unwarranted, is perhaps a waste of time, as it would be practically impossible to safely remove from within the socket's mating receptacle(s)....
Hello, if it is just a tiny amount then hopefully probably won’t hurt anything but if it covers many pins might want to try and clean It up possibly. Do what you want man I’m not a pro just a kid.
