Thermal paste cleaning
Apr 2, 2018
4
I want to remove my thermal paste because I want to change my cpu fan, but I’m to cheap to buy 99% alcohol.
Can I use slightly wet toilet paper to clean it off?
You don't have rubbing alcohol around you in a medical safety kit? You might even find it in some hand sanitizers. You don't have access to nail polish remover?
Slightly wet toilet paper wont get anything off, instead will cause it to crumble/spill over to other areas.
Can i just use non wet toilet paper?
