Thermal Paste Comparison, Part Two: 39 Products Get Tested
TehDudeMan
Great article guys! As a reader for over 10 years pretty much daily, this reminds me of the old Tom's Hardware. These type of in depth articles on enthusiast products are what I love.
Matt Edwards
A great article, agree the application of the compound, not the compound itself is most important.
Like ledpellet I too am curious about these diamond compounds. Wonder if it offers similar results to the Coollaboratory products with an easier application, or if the results simply don't justify the price. E.g in Australia, Innovation Cooling IC7 Diamond 7 Carat Thermal Compound Paste - 1.5G can be found for as much as $25. The cheapest I have managed to find it for is $15. For that price it would want to be good considering the leading GELID GC Extreme, can be found for around $8.
danwat1234
1,400
6
19,315
Coollaboratory Liquid Ultra isn't all that good after a year of hard use. In fact, it completely hardens / dries. On my X9100 after 9 months of nearly 24/7 100% load, I started seeing high temps and after 1 year auto shut downs while crunching. Turns out it was shutting off because it hit the 105 C thermal protection.
Opened it up; thermal compound was as hard as a rock. has to pocket knife blade and sand it down.
So for longevity it sucks. That is something to consider, not just initial performance, but performance months and years down the road. Especially for laptops that aren't designed to be opened up frequently for repasting.
After trying Liquid Ultra many times and having it fail on me, I've put on Arctic MX-2 that has a supposed 8 year durability rating. Initial performance is great, we'll see how it lasts (been 3 weeks so far).
G
Guest
Guest
All the hype aside, could Tom's include an actual industrial "Silicone Heat Transfer Compound", such as the one by MG Chemicals :http://www.mgchemicals.com/products/greases-and-lubricants/thermal-greases/silicone-heat-transfer-compound-860/, any of the future comparisons. If this stuff is good to use in mass industrial applications, how can it not be any better then let's say AS5.
Plus, AS5 can short out your mobo if some of it gets on the PCB and it costs 10 times as much as the industrial stuff and I don't think it is 10 times better.
yannigr
140
The good old Ceramique should have been in the list. Nevertheless nice article. Disappointed with the tooth paste. Expecting more from it.
rwinches
888
Coollaboratory Liquid MetalPad sounds ideal.
Might there be a way to achieve proper bond by heating the pad as well as getting the cpu hot?
I guessing this would be most ideal for GPUs though, as they want to get very hot.
Technoart
61
You guys should see how big tube of thermal paste and how big is the thermal tape that are available inside AMD. All of this product are obsolete.
Technoart
61
Standard thermal paste is good enough to conduct heat but buy high aluminum or silver content based thermal paste will serve your HSF and CPU coolly. I'm talking about industrial grade thermal compound. Try to get one from the manufacturers. 3rd Party based like CM, Arctic Silver and more still not good enough for our HSF and CPU. This is because when your CPU heat up so fast and cool down rapidly, your thermal compound may degrade fast until you thermal compound is flow to the sides of your CPU's IHS.
BigMack70
141
FANTASTIC article! Extremely informative and helpful, especially for newbies or anyone like me who hadn't ever seen the liquid metal compounds in action before.
I'm personally partial to Noctua's NT-H1... I've gotten pretty nice results with it, and I love how easy it is to use compared to other compounds I've had. Might try the Gelid GC extreme at some point in the future when I run out of Noctua's NT-H1, though.
Also, a big +1 for the lulz of using toothpaste and denture adhesive :lol:
