[SOLVED] thermaltake 530w smart SE
Sep 9, 2019
4
my pc i7-3770
i want to buy rtx 2060 zotac amp edition
my psu thermaltake 530w smart SE
is this psu can handle my cpu and gpu?
That's an Okay-ish PSU, but it's not the very best of power supplies. It will work. But I would recommend something else in it's place if possible - especially powering a discreet GPU.
Can you get some other high quality power supply ? Maybe a SEASONIC Foucs Plus GOLD, or Corsair's RMx series ? Anyways, here is the full review of this PSU, assuming this is your actual PSU Model.
Is this your PSU, or some other model ? Because it doesn't say SE here, imo.
https://www.overclockers.com/thermaltake-smart-series-530-power-supply-review/
I usually recommend the following GPU models for high-end Gaming PCs. These are high quality units. Look for similar SKUs.
SEASONIC PRIME, and Prime Ultra, or FOCUS Plus GOLD, Focus Plus Platinum.
CORSAIR AXi, RMi, RMx 550/650W, SF, HX 2017, HXi.
FSP - Hydro PTM 550/650W.
Cooler Master - MasterWatt Maker MiJ, V series 550/650W.
Antec - High Current Pro, High Current Platinum, Earthwatts Pro Gold, HCG Gold.
Super Flower - Leadex Gold II.
be Quiet! - Dark Power Pro 11, Straight Power 11, Dark Power Pro P10.
EVGA -Supernova.
EVGA -Supernova.
maybe i take cx550w corsair
What about the other PSU options which I have suggested ? Are they available in your country, and can you afford them or not ?
