…and cuts the price below standard RGB version
Thermaltake Adds ARGB Model to Level 20 GT : Read more
Addressable RGB, which means it has a digital controller on the device and a data pin on the header. It allows you to do more with patterns and timingWhat does ARGB mean and how is it different than RGB?
Thanks for chiming in. Google was telling me "Alpha RGB" and I was thinking adding an alpha channel would be at best a minor convinience to whomever writes the driver that nobody else would notice.Addressable RGB, which means it has a digital controller on the device and a data pin on the header. It allows you to do more with patterns and timing
I'm not sure, but you can find out what the related cables are using with a Google search, the long version of the name is "digitally addressable RGB LED", and the users fought over various names like DLED and ADD-LED until finally settling on ARGB as shorthand.Thanks for chiming in. Google was telling me "Alpha RGB" and I was thinking adding an alpha channel would be at best a minor convinience to whomever writes the driver that nobody else would notice.
So I assume it uses a common WS2812B or similar?
