Alright heres the problem: I installed a new LED case fan from ThermalTake and Its constantly running at full speed, causing my air pressure to be screwy and its very loud.
It has 2 connectors coming out of it, one molex and one 3-pin. Ive tryed to with just the 3-pin but it didnt even turn on so now Ive got the molex connected to the PSU and the 3-pin connected to the motherboard. Problem is: I can see the fan in the BIOS but no matter what I do it always runs full speed. Ive tryed putting it to 'Silent" mode as well as giving it a manual RPM but nothing seems to work.
Is this a common problem and theres a quick life-hack that will fix it? Do I need to get a new case fan?
Not sure if this is the exact model but I found it on google and it looks exactly the same:
Thermaltake 120mm Blue LED Case Cooling Fan CL-F012-PL12BU-A
