I've plugged in the 200mm 3-pin system fan to the 4-pin header and the fan works at full-speed only. In the bios there is the option to set fan control for the system fan but the options are "Disabled" or "Auto". Auto seems to use PWM and there doesn't seem to be a way to specify voltage control and after studying the forums I assume that I need to change my fan to a 4-pin PWM.
Would a fan controller allow the motherboard to control the 3-pin fan? How would this work? Would the controller convert the PWM signal sent on the 4th pin and modify the voltage on the relevant pin on the controller fan header? Or am I misunderstanding?
