So I recently installed four 120mm thermal take pure plus fans to my moba using the usb pin which is then connected to a controller which connects all the fans. For some reason the fans do not appear in the BIOS though they do appear in thermal takes software TT rgb plus
The reason i want to control it from the moba is because the pwm option in the software is so horrible the fans are running to slow causing the components to heat up so i always set the fans to 80%
btw what is an average temperature for a GPU and CPU when on load
