[citation][nom]reyshan[/nom]can someone elaborate what below/above ambient temp? my 960t @3.6 on a Thermaltake ISGC-400 idles around 13-15c at 22c room temp and load up to 24c. all my sensors are workin properly.[/citation]
either your sensors are not working properly, or it is displaying a temperature the CPU is above the ambient temperature.
Ambient temperature is merely room temperature, or the temperature 'around' (which is what ambient means) the object in question.
Think of it this way: Your CPU conducts electricity through tiny pathways, each of those pathways has an amount of friction between the electricity and the 'walls' of the pathways that they travel down. This friction is what causes heat, and that heat must be transferred elsewhere before it gets too hot and ends up melting something. The more pathways that are used, the more heat buildup becomes a problem. So you add a heat sink which draws heat away from the CPU, and then transfers it into the air flowing through the case. The more surface area, and the more airflow a heat sink has, the more effective it becomes (also, the more thermally conductive the material is helps. Like copper instead of steel). If the CPU was turned off, then the heatsink is merely going to take on the temperature of the air in the room, and thus make the CPU the same temperature as the room, this is the minimum temperature a CPU can have because it is 100% at rest. The moment you turn a CPU on it begins producing heat, which is why your CPU temp is ALWAYS higher than your room temperature. If it is not then something is wrong (granted, not terribly wrong... just like a car with a bad speedomitor; The car works fine... you just don't know how fast you are going, or when you are going to get into trouble for going too fast).
At any rate, the temps you are getting for your CPU are not right, because it is impossible without an active cooling component (meaning something cooling it that is below room temperature).
