Thermaltake V1 or V21 - PLEASE HELP
Jacob_107
190
I would like to build a MINI-ITX PC for studying and also light gaming but when finding a case I decided to go for Thermaltake V21 as I would like to choose a MicroATX motherboard. Could you suggest which case is better and what other cases are also for a reasonable price.
Both look the same and both are good , just make up your mind , itx or mATX
as for better cases ,
for itx , Check
1- Fractaldesign Core 500
2- InWIN 901 Gold with Side window
3- cooltek W1 with window
4-Lian Li PC-Q10WX black with side panel window
5-Lian Li PC-Q36WRX gold
6-cooltek u2
7-cooltek umx1
Thank you for your quick answer. I have checked out all the avaliable cases that you stated above, but I will probably stay with Thermaltake. I will only have to choose the case as I will decide if I wll go for Mini ITX or mATX. Do you think I should go for V21 anyway just in case I will want to upgrade from Mini ITX to mATX? Thanks again.
I personally think that the Thermaltake V21 has some good features and also looks good, but it seems just too big in width than a normal Mid Tower. I'm planning to use a Mini ITX motherboard so I could easily fit all my components inside the Core V1, but should I go for the Core V21 instead V1 or a normal Mid Tower?
