Thermaltake vs NZXT Cases
nicholas69691
33
Hello,
I am going to be building a pc and found some decent cases. I have been keeping an eye out on the Thermaltake C21 RGB, but wasn't sure if I should go for that case, or an NZXT S340. I'm looking for a case that is around 100 aud, and wouldn't mind suggestions apart from these 2. Which case should I get? I'm looking for a case with space and good cable management, as well as good airflow. If it comes with more fans that would be even better, thanks.
Wow, I didnt even know that it existed. Would you recommend I get that or the corsair spec alpha? I'm looking for a second opinion
I'm talking about the spec alpha, not the spec 04. Either way, I'm gonna go with the P400S from phanteks, as pccasegear dont have an actual store, and I'm not trying to spend half of my case budget on shipping.
Yes that P400S case is good. I thought it was overpriced as your budget was $100.
Yeah, no fault there, but I found that I would have spent at least 120 dollars for the cases and fans, and I'd rather spend 130 dollars on the case than spend 100 dollars on the case and then 30 dollars for shipping. Thanks for your help, you have been very useful
