I'm looking to buying another monitor and a graphics card, problem is my EVGA GTX 760 SC 4gb is discontinued, and i'm having a hard time buying one for a decent price. So i was wondering if i could go with a different card.
... You can use a second 760 of any brand with your current 760.
You're absolutely free to change your 760 to a 980, but if you think you can use both a 760 and a 980 together, well... it just doesn't work like that.
Note that if it's not a 4GB card, your current card will only use part of its ram, and in the same way, unless you overclock the new card to match the speeds of your current one, your current one will downclock to match the new card.
