I recently got my third monitor. It worked fine, until 2-3 weeks later. (I've got a DP,HDMI and DVI input, they are all used.) My HDMI and DVI monitor wil work together, and display and DVI also work. But if i use all of them at the same time, (DP,HDMI and DVI) my DP monitor won't work.
Is this something that happens more ?Is it a problem with my GPU?
Does anyone have experience with this? If so please answer if you have a solution.
Thanks!
Thanks!
