This is my first computer build and I was wanting to know how these components will work together primarily the size of the parts.
1. Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811208027
2. Power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817152033
3. mother board http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
4. Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
5. Graphics Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814187069 or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133304
6. cpu heat sink http://www.newegg.com/Product/Product.aspx?Item=N82E16835185125
I know these are not all the parts needed but they are the most important, and the ones I'm most concerned about.
Thanks
Thanks
