Question Thoughts about my first build
Aug 24, 2019
8
Hey guys,
I'm almost done picking the parts for my first ever PC build. I would appreciate some thoughts.
I would mainly use the pc for architectural work, rendering and modeling, and some gaming.
This is my build so far:
I would appreciate your opinion
Sent from my ELE-L29 using Tapatalk
liamwhalley20
Proper
Nov 27, 2018
200
27
120
looks like a good build,i would remove the hyper 212 though as the 3600x comes with adequate cooling anyway with the wraith cooler, can overclock with that cooler also :) have you already got a case for your build?
Aug 24, 2019
8
No I haven't. I thought that I would pick out the case, when I'm getting the parts. Is there anything that I should know when picking the case concerning this build? :)
Thanks
Samrat97
Great
Apr 8, 2019
103
Hey guys,
I'm building Ryzen 5 3600 With an aftermarket cooler.. 🙂
Audio31
Commendable
Feb 10, 2017
40
From what I've been reading there is not much difference in the 3600x and the 3600, just get the 3600. Do you need 32gb ram? I've 24gb but 16gb is enough for most of everything I've used.
Change parts around get a 2070 instead.
Aug 24, 2019
8
Yes, I did watch some reviews, but couldn't find anything about rendering and modeling. Does the clock speed difference have a big impact on single core perofmance? Since that's what's used in modeling.
Samrat97
Great
Apr 8, 2019
103
I would suggest you follow CG director / Logical Increaments
You'll find your answer..
Samrat97
Great
Apr 8, 2019
103
That's like an alternative, right?
Yes.. I have the budget for 3600X bt it's not worth it for my purpose..
R5 3600 is a little beast..
I'm considering it over i7 8700..
My purpose is Music production and Video editing on Adobe Premiere Pro
