Thoughts on NZXT H440
maniaczzz
Commendable
Mar 12, 2016
4
Hello Tom's community !
I'm new here and I'm building a PC for myself.
My PC Specifications are :
Intel Core I5-6600K 3.50 GHz (Gonna OC it to 4.6)
EVGA GeForce GTX 970 4GB SSC Gaming ACX 2.0+
Corsair CX Series, CX600M, 600 Watt (600W), Semi Modular Power Supply, 80+ Bronze Certified
WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 2666MHz
Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler
Asus Z-170 Pro Gaming
SanDisk Ultra II 480GB (Will buy probably)
I want to know user opinions about the H440 how cool it keeps your PC, how loud or silent it is. It's really good in terms of aesthetics but is it good enough in terms on cooling?
Ideal temps and temps under load?
I'm open to suggestions to other cases of any brand price would be 150$ max, also I will order SanDisk Ultra II 480GB should I get it? I'm getting it for a discount so is it worth it?
Thanks
its a greta case but indeed the cooling is not the best.
you can replace the fans with some premium noctua fans(best fan maker).
than u got a great case
i would really upgrade yoru psu man.
because nothing happens it doesnt mean it can damage your components over time.
if u got time google corsair cx exploded or blew up, u get tons of pages.
Sadly I got PSU earlier without thinking much D:
H440 has pretty less ventilation holes is it still good to keep my rig cool?
