Thoughts on pc parts
Djm1025
I'm 14 and thinking to build a cheap gaming pc. This is my first time and I don't know that much about pcs but I've picked these parts so far. Any thoughts on better parts and what hdd, ssd and case I should get.
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Intel+Motherboards-_-N82E16813157303&gclid=CISvzMTV_bUCFe4-
Graphics card: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4501123&SRCCODE=WEBGOOPA&cm_mmc_o=mH4CjC7BBTkwCjCV1-CjCE&gclid=CK_csvjV_bUCFcZFMgoddjIA3g
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820139046&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Desktop+Memory-_-N82E16820139046&gclid=CN2To83W_bUCFdOHMgodMG8A3Q
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653 (for overclocking the 3570k; otherwise get a non k cpu with your h77 asrock board)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233117
http://www.newegg.com/Product/Product.aspx?Item=20-171-645&IsVirtualParent=1 (handle with care; I mount mine with two screws on the side of my large htpc case, or use mounting tape sticky on both sides) When installing, install the ssd and then install windows; after installing, install your main drive while windows is running so it can configure it as a secondary drive. I clone my drives with seagate maxblast software.
