HI everyone,
My cpu seems to be running hot. I used to idle in the upper 20s / low 30s. but now its idling around 50 and getting towards 80c under load. Even when I used to benchmark it would barely hit upper 60s?
Any thoughts ?
4790k stock
h110i gtx AIO
z97a gaming 7
32 gb ddr3 hyper x stock settings
1080ti ftw
760t case
2 140s blowning in the front, one 140 blowing in from the rear, and the AIO mounted on top blowing out with two 140s and a third 140 blowing out as well.
Never had issues.. I did recently swap to the 1080ti but it didnt have issues. I then noticed it a bit warmer here and there so I removed the AIO, blew some air all around to clean dust. Cleaned and reaaplied thermo. all was good
I played around (and the system seemed to run better and cooler) when I OC'd to 4.7ghz at 1.275v just to run some benchmarks when I got the ti. All seemed well. I reverted back to the defaults in the bios and here I am running into hot temps for no apparent reason.
Also the room is about mid 60,s temp..
Any thoughts would be great.
https://ibb.co/gKOXow
Any thoughts ?
4790k stock
h110i gtx AIO
z97a gaming 7
1080ti ftw
760t case
