Three 4k monitors and one 1070, will it work?
sheakev
18
I have two 4k monitors (LG 27") and want to add a 50'LED 4K TV screen. This is not for gaming.
My question is will this work or do I need to another 1070 card?
For non gaming the 1070 will be more then enough, you could even get away with a cheaper card. Just wonderinb what are you using all 3 screens for?
It's for my amateur (Ham) radio setup. The big screen will have realtime propgation maps. The other two have programs for running the software defined radio (no knobs), encoding and decoding signals, and a couple of browser windows.
I built my computer about 18 months ago. It has a Intel - Core i7-6850K 3.6GHz 6-Core Processor and runs Windows 10 Pro 64 bit. It has 32 Gig of memory and a SSD for my programs and a hard drive for files.
None of this is too resource intensive, the radio (just a black box) has fairly powerful processors so the computer is really just for input and display.
I see, so yea the 1070 is plenty for the build, just make sure it has enough connections for your monitors and 4K tv.
It has just enough of the right connections the two existing monitors are DisplayPort 1.2 and the 4K TV will use and HDMI 2.0
Thanks for quick and reassuring response
