[SOLVED] Tick sound?
Sep 7, 2019
8
My computer sometime make a tick sound then my screen froze after that like 10 seconds it will make a tick sound again and continue working
It's kind of annoying
Karadjgne
Herald
In windows start, scroll down to where it says Command Prompt as Administrator.
Type in chkdsk /f /r C:
Let it run.
Honestly sounds like you gave the pc a good smack while it was running and made the armature scratch the disk in the hdd. So you'll need to isolate that section and have windows avoid using that area.
You'll need to replace the hdd at some point, it's a physical defect now, and not fixable as such.
Sep 7, 2019
8
OK i don't know what i'm supposed to do with it i started the program and
"The status of the hard disk is not perfect. Seek Error Rate = 1
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
No actions needed."
So what now?
Karadjgne
Herald
Let it run.
