Problem with salt likely is that it is corrosive. Plus I am not sure if it even is more thermally conductive.
Also for liquid metal, you really do have to commit to it. Mixing it with paste won't work. Also I would put my money on him forgetting that liquid metal needst to be spread on both sides, heatspreader or die, in case it is delided, and also cooler, because it is actually really bad at connecting or bonding with other materials. You can't just plop drop in the middle like thermal paste. Also to protect components around it you can use nail polish to create non-conductive layer on components around CPU. Also to prevent leaks you need to apply just right amount. Though having paste around, it likely would squish it away anyway, but at least liquid metal would have some kind of chance.
