ub157 Aug 1, 2024 1 0 10 Aug 1, 2024 #1 I have a monitor that is rated 100-240V at 50-60Hz powered with a C13 cable (type E plug, 230V) To use it at 100V 50Hz, will using one of the cheap plug adapters be enough? Or do I need something more? Thank you!
Solution Phillip Corcoran Aug 1, 2024 As the monitor is already rated to support 100v at 50Hz, all you need is a simple plug adapter.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,102 912 120,140 Aug 1, 2024 Solution #2 As the monitor is already rated to support 100v at 50Hz, all you need is a simple plug adapter. Upvote 0 Downvote Solution
