So I was doing my annual PC dust cleaning where I take my PC outside and blast it with air. But after a couple of days my PC was making an annoying short squeaking noise, which I located it to my PSU. I opened it up and added sewing machine oil to the fan bearing and closed it back again. It solved my first issue but it seemed to cause another because after that I started hearing a buzzing/humming sound that I haven't heard from it before. I figured that maybe I added too little oil and so I went through the process of opening it back up again and I added another couple of drops but it didn't seem to have made a difference.
Something that DID help however was that I opened up the case and rearranged a few cables and other things. The vibrations were much less audible after that. Now it's so hard to hear that I'm going crazy because I don't know if I fixed it and I should ignore the issue or if it's still there...
Now I'm worrying if I might have done more harm than good. May have added too much oil? Should I open it up and carefully suck some back up with a piece of tissue? Could this harm my fan and PSU in any way or is this really nothing to worry about and I should just ignore it?
