[SOLVED] Toshiba 18TB HDD problem
Sep 12, 2024
I have a Toshiba 18TB hard drive, model number MG09ACA18TE. Recently, I found that it seems to be malfunctioning. Its capacity has been used up to about 90%, with only a little over 1TB of capacity remaining. I often encounter system freezes when reading files from it, and then the drive letter disappears. After restarting the computer, I can see the drive letter again, but the same issue occurs when I try to read some files again. I tried writing some files to the remaining space, and it worked fine.
Therefore, I suspect that there is a fault with the hard drive. I used Diskgenius to completely clear the sectors of the hard drive and then checked for any bad sectors, but there were no bad sectors found. So I wrote a program in Python to generate some 1.5GB files and write them to the hard drive. Initially, everything was fine, but when the hard drive was full and the last file prompted an error in Python, the drive letter disappeared again.
I am not sure if the hard drive has a hardware fault, and I do not want to continue using it to store my data. My hard drive is still under warranty, and I want to contact the manufacturer's after-sales service. However, I am not sure if they will be able to reproduce the issue once they receive the hard drive. If they only test for bad sectors using software like DiskGenius, they may not find the issue.
So what should I do now? Can anyone offer some advice?
CPU: Intel Core i5-9600K
CPU cooler: unknown
Motherboard: Asus Prime B360
Ram: Kingston 16GB *4
SSD/HDD: Samsum EVO970 SSD 2TB/ Toshiba MG09ACA18TE/ 18TB
PSU: Golden Greatwall 650W
Chassis: unknown
OS: Windows 7 Professional 64bit
Monitor: Samsum 27 inch 2K
Mainboard: Asus Prime 360
Hard Drive:Toshiba MG09ACA18TE
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
You might want to see if increasing your empty drive space to 2TB helps.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
The corresponding information has been added. You mean maybe because there's not enough space left? But I just read file from HDD, did not write, the drive letter disappeared also.
And why is 2TB? Does this number of capacity have any special significance?
After months of suffering, I finally solved the problem. I bought a PCIe to SATA interface card, model DIEWU JMS585, and I planned to connect the hard drive to it instead of using the SATA interface on the motherboard. After disassembling the computer case, I found that my 18TB hard drive was sandwiched between a CDROM and another hard drive. The temperature of the outer shell was very high, so I moved it to another set of hard drive brackets, which was located at the air inlet of my case fan. Then I arranged the power cords to evenly distribute the load on each power supply.
After doing all this, my computer has been turned on for more than 24 hours without any problems. Before, it would disconnect almost every hour, and I had to refresh the device in the disk manager to make the drive letter appear again.
I'm not sure which of the above reasons was the decisive factor, but the problem was solved.
