Question Toshiba Satellite fan does not run?
Oct 28, 2020
9
Fan stopped running on Toshiba Satellite C655D(-S5531) after disconnected 4 pin fan lead by mistake, while trying to fix a broken case (I think), about 8 months ago. Fan used to have very good air flow and would run when charging with computer booted. Now the fan does not run by itself anymore; no air flow from the exhaust and I can feel the temperature of the HDD get warm. When the HDD is warm, the system slows down substantially, leaving programs "not responding" or not accepting mouse input for 10 to 20 seconds at times.
One Toshiba forum suggested checking for a sense thermistor (on a 3 pin fan) to verify its operation; so I tried a heat gun on the fan while the system was running and the fan turns on, but does not have the high air flow it used to have.
Another post used SpeedFan to check the cooling system operation. When I installed SpeedFan, found 3 fans and 4 temperature sensors: HD0, Temp1, GPU and Core. Found the HDd0 temp show red about 50C, but fan does not turn on. Temp1, GPU and Core show red about 42C (but this varies), and still no fan speed nor air flow. SpeedFan documentation is a little terse for me, and it looks like the author no longer supports it. Appears SpeedFan does not allow direct fan manipulation (can't just turn one on).
Swapped out the fan and got the same results with the replacement fan; fan still does not run. Obviously there must be some other control for the fan that I am missing. Could this be a BIOS fault or motherboard fault? Any suggestion how to proceed would be appreciated.
DriverUpdate Utility suggests Realtek RTL8188CE Wireless LAN 802.11 Network Adapter and Standard AHCI 1.0 Serial ATA Controller are out of date. But Windows Update Driver determines the SATA driver is up to date. And the fan problem occurs whether or not it is in a wifi area. The fan problem also occurs in Linux flavors Debian and Ubuntu, which presumably use different drivers.
SpeedFan continues to show several temperature sensors at or near a 50C critical level (red flame icon) but all of the fans show 0 RPM. The fan may actually turn at a slow speed as I can hear a slight sound (either from the HDD or fan) and I can also feel some heat exiting from the exhaust port. The system response continues to degrade, with up to minutes at a time in a wait state (sometimes mouse frozen or unresponsive apps). Think it may be waiting for the HDD.
Does anyone have an idea about how disconnecting the fan connector from the motherboard could cause the fan to essentially stop? It used be noticably loud and have high heated exhaust flow.
Forget the drivers. Those temperatures you mention for gpu / cpu and motherboard are completely fine which sometimes does not even trigger the fan (depends on bios). Harddrive / ssd is not cooled by the laptop fans. Do you mean 50c+ for the HDD?
Download HWmonitor and show the temperatures send pics here
Might be dying hdd or something else, if you can fix hdd errors with chdsk (google it theres loads of tutorials) , if this fixes it temporarily you just need ssd/hdd (I suggest ssd)
Today SpeedFan is getting Temp1, GPU and core above 50 degrees centigrade (all with flame icon) after an hour at the library. Also getting really slow response times (several Notepad activations stacked one after another; all open when clearing desktop; also same for other apps). Yesterday it was only GPU, I think, and it fluctuated (> 50C flame icon, returned to green check mark < 50C). HDD used to be hot (> 50C, I could feel the heat from the case cover), but today it is 37C. The last time I took top cover off, the HDD cover was not seated and there is an air gap now. So it is cooling the HDD a little more. The fan does cool the HDD. One fan for the whole system, when it runs it draws the heat from the whole interior of the case.
You said "Download HWmonitor and show the temperatures send pics here" but where do I find the HWmonitor? Is this part of SpeedFan? I also suspect the HDD (not SSD) is overheating and causing scheduling delays (erratic performance, especially after some warm up time). But today the HDD registers a good temp, while other sensors are hot. My thought was it might be a motherboard problem, as the sensors seem to work, but the fan does not run (at least, not at full speed).
Hwmonitor is different software just google it and download, then test under load what you are getting on max temperatures for cpu cores , graphics card and hdd/ssd
Included Monitor data from CPUID HWMonitor after hour+ on library wifi. Can't see fan info and no breakdown for HDD (unlike SpeedFan). Don't know how to interpret all the data:
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.2.0
Monitoring
Mainboard Model Portable PC (0x000003EC - 0x103CB030)
LPCIO
Hardware Monitors
Hardware monitor ACPI
Temperature 0 45 degC (112 degF) [0xC6E] (THZN)
Hardware monitor Battery
Voltage 0 10.80 Volts [0x2A30] (Current Voltage)
Capacity 0 47520 mWh [0xB9A0] (Designed Capacity)
Capacity 1 29527 mWh [0x7357] (Full Charge Capacity)
Capacity 2 6792 mWh [0x1A88] (Current Capacity)
Level 0 38 pc [0x3E] (Wear Level)
Level 1 23 pc [0x17] (Charge Level)
Hardware monitor D3D
Hardware monitor AMD ADL
Voltage 0 0.86 Volts [0x35E] (GPU)
Temperature 0 45 degC (112 degF) [0x2D] (GPU)
Clock Speed 0 278.58 MHz [0x116] (Graphics)
Clock Speed 1 533.00 MHz [0x215] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 2
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
Timers
ACPI timer 3.580 MHz
Perf timer 1.266 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Manufacturer AuthenticAMD
Name AMD E-300
Codename Zacate
Specification AMD E-300 APU with Radeon(tm) HD Graphics
Package Socket FT1 BGA
CPUID F.2.0
Extended CPUID 14.2
Brand ID 8
Core Stepping ON-C0
Technology 40 nm
Core Speed 1111.6 MHz
Multiplier x Bus Speed 11.14 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (ext.) 99.8 MHz
Stock frequency 1300 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4A, x86-64, AMD-V
Microcode Revision 0x5000101
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000006h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
FID/VID Control yes
Min FID 7.8x
Max VID 1.350 V
# of P-States 3
P-State 1300 MHz - FID 0x200 - VID 0x10 - IDD 4 (13.00x - 1.350 V)
P-State 1114 MHz - FID 0x202 - VID 0x12 - IDD 3 (11.14x - 1.325 V)
P-State 780 MHz - FID 0x400 - VID 0x23 - IDD 2 (7.80x - 1.112 V)
Max PLL Frequency 3900
Package Type 0x0
Model 31
String 1 0x2
String 2 0x9
Page 0x0
Boosted P-States 0
Max non-turbo ratio 13.00x
Max turbo ratio 13.00x
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Attached device PCI device at bus 0, device 24, function 5
Attached device PCI device at bus 0, device 24, function 6
Attached device PCI device at bus 0, device 24, function 7
Clock Speed 0 1111.63 MHz (Core #0)
Clock Speed 1 1111.63 MHz (Core #1)
Core 0 max ratio 13.0 (effective 13.0)
Core 1 max ratio 13.0 (effective 13.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00500F20 0x00020800 0x00802209 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00500F20 0x000011F9 0x000035FF 0x2FD3FBFF
0x80000002 0x20444D41 0x30332D45 0x50412030 0x69772055
0x80000003 0x52206874 0x6F656461 0x6D74286E 0x44482029
0x80000004 0x61724720 0x63696870 0x00000073 0x00000000
0x80000005 0xFF08FF08 0xFF280000 0x20080140 0x20020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003024 0x00000000 0x00001001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000008 0x00000000 0x0000060F
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010061 0x00000000 0x00000020
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x8000012B 0x00002020
MSR 0xC0010065 0x8000011C 0x00002422
MSR 0xC0010066 0x800002A5 0x00004640
MSR 0xC0010067 0x00000000 0x00000000
MSR 0xC0010068 0x00000000 0x00000000
MSR 0xC0010058 0x00000000 0xF8000019
MSR 0xC0010015 0x00000000 0x01000011
MSR 0xC001001F 0x04004000 0x00000200
MSR 0xC0010071 0x002E0082 0x6E002020
MSR 0xC0010070 0x00000000 0x00000000
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00500F20 0x01020800 0x00802209 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
Storage
Drive 0
Name TOSHIBA MK3275GSX
Revision GT001M
Serial Z11EPCXBT
Capacity 298.1 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 5400 RPM
Features SMART
Volume c:\, 25.0 GBytes (15.1 percent available)
Volume d:\, 40.0 GBytes (12.7 percent available)
Volume e:\, 35.0 GBytes (39.1 percent available)
Volume f:\, 81.5 GBytes (20.3 percent available)
Volume g:\, 13.7 GBytes (4.2 percent available)
USB Devices
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x3938, product=0x1031
USB Device USB Composite Device, class=0xEF, subclass=0x02, vendor=0x10F1, product=0x1A34
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2000000
Name AMD Radeon HD 6310 Graphics
Board Manufacturer Toshiba
PCI device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Vendor ID 0x1002 (0x1179)
Model ID 0x9802 (0xFDE8)
Revision ID 0x0
Performance Level 0
Core clock 278.6 MHz
Memory clock 533.0 MHz
Performance Level 1
Core clock 487.5 MHz
Monitor 0
Model ()
ID IVO03F4
Serial
Manufacturing Date Week 28, Year 2017
Size 15.3 inches
Max Resolution 1366 x 768 @ 59 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
_GPE
_L08
_L18
_L03
PR
C000
_PCT
_PSS
XPSS
_PSD
_PPC
_CST
C001
_PCT
_PSS
XPSS
_PSD
_PPC
_CST
C002
C003
SB
PWRB
_HID
_STA
PCI0
_HID
_CID
_ADR
_PS0
_PS3
_INI
NBMS
MIDX
MIDR
NBMM
NBMR
NBMW
NBXP
NBXI
NBXD
NBXM
NBXR
NBXW
GFXM
GPPM
GPPX
XPTR
XPLP
XPLL
_UID
_BBN
SUPP
CTRL
AMHP
TOM_
CRES
_CRS
MEMR
_HID
MEM1
_CRS
XCMP
AFN0
AFN1
AFN2
AFN3
AFN4
AFN5
AFN6
PR00
AR00
_PRT
BRLV
PANL
VGA_
_ADR
PXEN
PXID
PXMX
LCDT
DSCT
PXFX
PXDY
AF7E
_STA
DOSA
BCML
_DOS
_DOD
LCD_
_ADR
_BCL
_BCM
_BQC
ATIB
ATIF
AF00
AF01
PSBR
MSKN
SEXM
STHG
STHI
SFPG
SFPI
SSPS
SSDM
SCDY
SACT
AF02
AF03
AFN0
AFN3
AFN4
AFN5
AFN6
AF15
REVD
SROM
VROM
TVGA
XTRM
ATPB
DSID
HSID
CNT0
CNT1
CNT2
CNT3
CNT4
CNT5
CNT6
CNT7
CNT8
CNT9
ATPX
PX00
PX01
PX02
PX03
PX04
PX08
PX09
AT00
AT01
ATCS
ACT0
ACT1
ACT2
ACT3
ACT4
PB2_
_ADR
_PRT
PB3_
_ADR
_PRT
PB4_
_ADR
PR04
AR04
_PRT
XPEX
VC0S
PCFG
DVID
PCMS
SBUS
XPCB
LKCN
LKST
PSDC
PSDS
HPCS
PMES
XPRI
XPIR
XPID
XPDL
XPRD
XPWR
XPRT
XPPB
XPCN
XPPD
XPLP
XPR2
XPLL
XPPR
VGA_
_ADR
PCFG
DVID
SVID
SMID
DOSA
BCML
_DOS
_DOD
LCD_
_ADR
_BCL
_BCM
_BQC
ATIB
ATIF
AF00
AF01
PSBR
MSKN
SEXM
STHG
STHI
SFPG
SFPI
SSPS
SSDM
SCDY
SACT
AF02
AF03
AFN0
AFN3
AFN4
AFN5
AFN6
AF15
_RMV
HDAU
_ADR
PCFG
DVID
SVID
SMID
_RMV
PB5_
_ADR
PR05
AR05
_PRT
PB6_
_ADR
PR06
AR06
_PRT
PB7_
_ADR
PR07
AR07
_PRT
SPB0
_ADR
PR0A
AR0A
_PRT
SPB1
_ADR
_PRW
PR0B
AR0B
_PRT
SPB2
_ADR
PR0C
AR0C
_PRT
SPB3
_ADR
PR0D
AR0D
_PRT
HPET
_HID
_STA
_CRS
AZAL
_ADR
PCI_
DNSP
DNSO
ENSR
USB0
_ADR
U0CS
U0EN
_PRW
_PSW
_S3D
_S4D
RHUB
_ADR
PRT1
_ADR
_UPC
_PLD
PRT2
_ADR
_UPC
_PLD
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
PRT5
_ADR
_UPC
USB1
_ADR
U1CS
U1EN
_S3D
_S4D
RHUB
_ADR
PRT1
_ADR
_UPC
PRT2
_ADR
_UPC
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
PRT5
_ADR
_UPC
USB2
_ADR
U2CS
U2EN
_S3D
_S4D
RHUB
_ADR
PRT1
_ADR
_UPC
PRT2
_ADR
_UPC
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
USB3
_ADR
U3CS
U3EN
_PRW
_S3D
_S4D
USB4
_ADR
_PRW
_PSW
RHUB
_ADR
PRT1
_ADR
_UPC
_PLD
PRT2
_ADR
_UPC
_PLD
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
PRT5
_ADR
_UPC
USB5
_ADR
RHUB
_ADR
PRT1
_ADR
_UPC
PRT2
_ADR
_UPC
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
PRT5
_ADR
_UPC
USB6
_ADR
RHUB
_ADR
PRT1
_ADR
_UPC
PRT2
_ADR
_UPC
PRT3
_ADR
_UPC
PRT4
_ADR
_UPC
SMBS
_ADR
IRQF
RVID
ERMM
G06E
G06O
G06I
G07E
G07O
G07I
G11E
G11O
G11I
G12E
G12O
G12I
G13E
G13O
G13I
G14E
G14O
G14I
G15E
G15O
G15I
G16E
G16O
G16I
G20E
G20O
G20I
G21E
G21O
G21I
G27E
G27O
G27I
G28E
G28O
G28I
G32E
G32O
G32I
G35E
G35O
G35I
GP41
G44E
G44O
G44I
G45E
G45O
G45I
GP46
G49E
G49O
G49I
G51E
G51O
G51I
G53E
G53O
G53I
G55E
G55O
G55I
G57E
G57O
G57I
G58E
G58O
G58I
G59E
G59O
G59I
GP63
G64E
G64O
G64I
GP66
GE05
G66E
G66O
G66I
GE11
G6EE
G6EO
G6EI
GE15
GE16
GE21
GE22
GPA6
GAAE
GAAO
GAAI
PD0E
PD0O
PD0I
PD1E
PD1O
PD1I
GB1E
GB1O
GB1I
GB2E
GB2O
GB2I
GB3E
GB3O
GB3I
GB4E
GB4O
GB4I
GB5E
GB5O
GB5I
GB6E
GB6O
GB6I
E01S
E05S
E15S
E16S
E22S
E01E
E05E
E15E
E16E
E22E
E01C
E05C
E15C
E16C
E22C
E01L
E05L
E15L
E16L
E22L
CLPS
G15A
SLPS
MT3A
EPNM
DPPF
PWDE
ALLS
TFTE
BLNK
PHYD
F0CT
F0MS
F0FQ
F0LD
F0MD
F0MP
LT0L
LT0H
MT0L
MT0H
HT0L
HT0H
LRG0
LHC0
F1CT
F1MS
F1FQ
F1LD
F1MD
F1MP
LT1L
LT1H
MT1L
MT1H
HT1L
HT1H
LRG1
LHC1
F2CT
F2MS
F2FQ
F2LD
F2MD
F2MP
LT2L
LT2H
MT2L
MT2H
HT2L
HT2H
LRG2
LHC2
F3CT
F3MS
F3FQ
F3LD
F3MD
F3MP
LT3L
LT3H
MT3L
MT3H
HT3L
HT3H
LRG3
LHC3
MX07
MX15
MX16
MX21
MX27
MX28
MX32
MX44
MX49
MX53
MX57
MX58
MX59
MX66
M102
M110
M175
M176
M180
M182
MS02
MS03
MS04
MS40
ECES
LPC0
_ADR
PSMX
DMAC
_HID
_CRS
COPR
_HID
_CRS
PIC_
_HID
_CRS
RTC_
_HID
BUF0
BUF1
_CRS
SPKR
_HID
_CRS
TMR_
_HID
BUF0
BUF1
_CRS
KBC0
_HID
_CRS
PS2M
_HID
_CID
_CRS
SYSR
_HID
_CRS
MEM_
_HID
MSRC
_CRS
LCLM
CLMI
CLMD
CLGP
IDRG
TSTS
TINT
I2CC
GPIO
RGPM
ADP0
_PCL
_HID
_PSR
_STA
BAT0
_HID
_UID
_PCL
BIF1
_STA
BST1
_BIF
_BST
ITOS
CHAR
BT__
_HID
_STA
BTST
AUSB
DUSB
BTPO
BTPF
ECOK
PWCG
INEV
LEGA
LGPA
LEGB
LGPB
LEGC
LGPC
LEGD
LGPD
WNBD
LRPM
HRPM
RCPU
EVCT
EIDL
GE2S
LDWK
VGAT
THRF
BCM1
FKST
EC92
EC93
EC94
EC95
EC96
EC99
EC9A
EC9C
EC9D
EC9E
EC9F
ECA0
ECA2
ECA3
ECA4
ECA5
ECA7
ECA8
ECA9
ECAA
ECAB
ECAC
ECAD
ECAE
ECAF
ECB6
ECB8
ECB9
ECBA
ECBD
ECBE
ECBF
ECC0
ECC1
ECC2
ECC5
ECC6
ECC8
ECC9
ECCA
ECCB
ECD7
ECDB
ECDF
ECE2
ECE3
HDS0
HDS1
HDST
HDSS
BCM2
PHC1
PHC2
BATI
PHC3
PHC4
PWMS
B1VT
B1CC
B1TP
MFAN
EVTC
ADVT
ACCA
ACCR
CPTV
CCLV
HSRL
BSS1
BSS2
FBFG
FBS3
EWRB
ERDB
BCV1
BCV2
EEV0
EEV1
EEV2
EEV3
EEV4
EEV5
EEV6
EEV7
SCRI
CLMM
OVLA
MUTL
LEVC
LEVB
LINI
TI3S
TIMC
SLEC
SLEV
SLEN
LREG
CLBF
CKEV
GEVT
ECLV
IDEV
CLRL
ILEV
LEVN
P2P_
_ADR
_PRW
PCPC
PCMD
IOW1
IOW2
PR48
PR49
PR4A
PR4B
PR09
AR09
_PRT
IDE_
_ADR
UDMT
PIOT
PITR
MDMT
MDTR
IDE_
PPIT
SPIT
PMDT
SMDT
PPIC
beloved patriot
PPIM
SPIM
PUDC
SUDC
PUDM
SUDM
GETT
GTM_
STM_
GTF_
PRID
_ADR
_GTM
_STM
P_D0
_ADR
_GTF
P_D1
_ADR
_GTF
SECD
_ADR
_GTM
_STM
S_D0
_ADR
_GTF
S_D1
_ADR
_GTF
PIRQ
PIDX
PDAT
PIRA
PIRB
PIRC
PIRD
PIRE
PIRF
PIRG
PIRH
PIRS
HDAD
GEC_
USB1
USB2
USB3
USB4
USB5
USB6
USB7
IDE_
SATA
GPP0
GPP1
GPP2
GPP3
KBDD
PD64
DSPI
INTA
INTB
INTC
INTD
PRS1
BUFA
IPRA
IPRB
IPRC
IPRD
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKE
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKF
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKG
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKH
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
GSMI
S80H
BSMI
APMC
APMD
ACPS
CPUS
CPUL
ECRO
ECRM
ECRS
ECRD
EGST
LCDS
CECS
CECP
HDMI
HKMD
TSBK
SDAT
DCIR
DBTN
HKEM
HSEM
IECC
HSWK
LCMD
SVCF
SWB0
SWB1
SWB2
SWB3
SWB4
SWB5
SWB6
SWB7
KYB0
IEC0
IEC1
IEC2
CECC
CECE
CECI
CECZ
CECF
CEC1
CEC2
CEC3
CEC4
CEC5
LENA
LENB
LENC
LEND
IFNK
ICMD
RESL
RESV
USC1
USC2
VGAM
USBM
TPID
NODD
IHDD
TJET
CPUM
POLI
TCCR
TEST
LCDA
PWM0
PWM1
PWM2
PWM3
PWM4
PWM5
PWM6
PWM7
EJLL
EJLR
OSYS
PNID
VGAN
CLMT
SCFG
KYBF
KYBA
SWBF
KYBB
F0CM
JFNK
CYCC
BTV1
BTV2
ILLU
MUTS
MUTE
PWBS
ACBS
ACBW
FTBT
LID0
_HID
_LID
_PRW
_PSW
RDEC
WREC
FLNK
FWEX
_HID
FWES
_STA
WFNK
SFNK
INIF
CAGA
CAGB
CAGC
CAGD
FNKC
RETP
USAC
BTCG
BCMF
BLBM
TINC
TINI
PARG
CKIF
RETA
HDSP
HDSB
GRPA
GRPB
PTST
GRPC
VALZ
_HID
_DDN
ENAB
INFO
SPFC
_STA
TWAK
TPTS
SPS0
SPS3
A001
AD01
A086
AD07
A087
A088
ALIB
A089
A007
A008
A052
A092
A053
A093
A050
A094
A042
A043
A028
A073
A059
A058
A081
A082
A083
A004
A003
A084
A085
AD02
A009
AD03
A010
AD04
A011
AD05
A012
AD06
A013
AD08
A014
A015
A016
A017
A018
A019
A020
AD09
A021
A022
A023
A025
A026
A030
A031
A040
A041
A045
A029
A046
A048
A055
A056
A057
A051
A054
A049
A047
A044
A027
A060
A061
A062
A063
A064
A065
A066
A069
A072
A070
A074
A076
A079
A075
A080
A078
A077
A002
A005
AD0B
A006
SI
TZ
PFA1
_STA
ON
_OFF
FAN1
_HID
_UID
_PR0
THZN
_TMP
_AC1
_AL1
_CRT
_SCP
_PSL
_PSV
_TSP
_REV
OS
_OSI
GL
XINI
DBG0
IO80
DBG1
P80H
ACMS
INDX
DATA
PSMI
APMC
APMD
PMRG
PMRI
PMRD
MMSO
HPAD
P1EB
SPRE
TPDE
RSTU
GSMM
GP51
GP55
GP59
GP64
GE01
GE11
GE12
BATS
G01S
G01E
TR01
TL01
ACIR
CLPS
G15A
SLPS
EPNM
DPPF
PWDE
ALLS
BLNK
PHYD
ECES
P1E0
PEWS
WSTA
PEWD
IOCC
RTCS
PRWP
GPRW
SPTS
SWAK
CHKH
GNVS
DAS1
DAS3
TNBH
TCP0
TCP1
ATNB
PCP0
PCP1
PWMN
LPTY
M92D
WKPM
ALST
AFUC
EXUS
TPCC
TPLC
TPLR
TPMM
AIRC
WLSH
TSSS
OGNS
OG00
OG01
OG02
OG03
OG04
OG05
OG06
OG07
OG08
OG09
OG10
TPID
OSYS
NVST
SMIF
PRM0
PRM1
BRTL
TLST
IGDS
LCDA
CSTE
NSTE
CADL
PADL
LIDS
PWRS
BVAL
ADDL
BCMD
DID_
INFO
TOML
TOMH
CEBP
C0LS
C1LS
C0HS
C1HS
ROMS
MUXF
PDDN
SCMP
WNOS
MYOS
HTTS
OSTB
TPOS
LINX
OSSP
CKOS
SEQL
OSTP
S0
S3
S4
S5
EAC1
CTMP
PLCY
CTTP
TPOK
F1ST
PICM
GPIC
_PIC
_PTS
_WAK
"Included Monitor data from CPUID HWMonitor after hour+ on library wifi. Can't see fan info and no breakdown for HDD (unlike SpeedFan). Don't know how to interpret all the data:
CPUID HWMonitor Report ... "
Took a screen shot of the HWMonitor page, but can't attach it to my reply. Is there a way to do this? The max temp I saw was 53C.
Just upload it some where and post a link
I don't really have any web site to put the picture on (sorry, I'm a little backward here). But I isolated the 3 temperatures from HWMonitor, and did another screen capture this morning:
THZN Assembly MK3275GSX GPU
20Nov20, 53C 39C 54C wo/vacuum on exhaust port
21Nov20 38C 23C 38C w/vacuum on exhaust port
I set up a vacuum cleaner hose next to the exhaust port and found noticeable drop in temperatures, versus the previous day without the vacuum sucking air out of the exhaust port. The system performance also improved, but still has some delays.
Looks like the problems would mostly disappear if I could get the fan to turn on. Any suggestions?
Found One Drive could share monitor screen shots; the link is
https://1drv.m/u/s!AlRBQMF4d9FNiTXuPVRujyvxSf8f?e=WU0AXe
It has HWMonitor data from before I cooled the system with a vacuum and also using the vacuum to reduce temperatures. The vacuum did reduce temperatures, but performance still had lags. Also got HDD Monitor data with SMART and Butterfly read test. First butterfly read test (not shown) took a long time starting with a line of red (>500ms) before the response improved (gray and green).
Installed a replacement motherboard this weekend. Hoping it would allow the fan to run at full speed, but it doesn't. The MB is used and may have problems; version upgrade from 1.20 to 2.04 and does not boot from the one primary Win7 partition; it does boot from grub2 into Win10, Debian and Ubuntu. There seems to be more heat out of the exhaust port and the top case at the HDD is warm again. I have included screen shots with the replaced MB including HDD SMART and Butterfly read, as well as HWMonitor data.
I suspect you are correct about HDD dying, although I can't be positive until the cooling problem is fixed. The system response with the replacement MB is looks a little better, but I don't know how long that will last. Wish I could isolate the fan problem to make it run at full speed. Any advice?
lga1156_ftw replied to a thread you are watching at Tom's Hardware Forum.
Question - Toshiba Satellite fan does not run?
Yeah that harddrive need to be replaced. You can also get SSD. Can you scroll down on the HWMONITOR so i can see processor temperature
Sorry, it has taken so long to get back with more information about the monitor data. When I installed the replacement MB, I lost the win7 boot; can only boot the win10 OS now.
I posted a 3 more images from HWMonitor (in HWM Comp folder).
https://1drv.ms/u/s!AlRBQMF4d9FNiWV6z9GsGwhdjmrL?e=8gyZAp
They all show the whole window; ending w/AMD E-300 (which is partially cut-off). For all of these there are 3 temperature lines: at top for THZN, 1/3 down for Assembly, and about at the middle for GPU; the values for the replaced MB are 46C, 28C and 45C, respectively in the top image; 48C, 32C and 48C, respectively in the bot image. These screen shots were taken on separate HWMonitor executions, so they have different values. The 23Nov image has 50C, 37C and 53C, respectively. These earlier values were with the original MB, and show noticably higher temperatures.
There is fresh heat sink paste on the E-300 processor on the replacement MB. The exhaust port with the replaced MB feels warmer than it was with the original MB. But the fan still does not have noticable air flow. In fact I still can't hear it. Don't know what these temperature should be, as I have no idea where to check the specs for this MB. Why won''t the fan turn on at full speed anymore?
The HDD does seem slow; response time is significantly slower than it was even a year ago. The Butterfly read tests show most ops < 50 ms. I have no idea what seek time should be. How far out of expectations are these access times?
Replacing the MB did not restore the high heat and large fan output. Finally replaced the HDD with a SSD. Fantastic response. Win7 boots in 30s and Win10 in just over a minute; the scheduling delays are gone (USB mouse still a little erratic). The top cover over the SSD is now cool.
The HDD monitor read tests respond in less than the minimum (<5ms 99.9% of time; 148 > 5ms out of 150,000 < 5ms ); previously the range was 50..150ms. Also the HW Monitor shows temperatures of 40C, 33C and 40C for the THZN (assembly, CPU?), SSD and GPU (display?), respectively. The ranges before replacing the SSD were previously measured at 50..58C, 37..39C and 53..59C, respectively.
Unfortunately, the DVD stopped working. So I swapped the MB back to the original and the DVD still reports an error to windows and cannot be used. Wonder if swapping MBs and parts so much damaged the DVD. Think the replacement MB had a little better response; maybe some heat damage to the original MB, but not sure. Now the heat flows out the exhaust port increase at times (feels a little warmer), but the fan does not run at high output anymore. Suggests the SSD does not need the higher cooling that used to be demanded with the old HDD (before the HDD SMART possibly stopped working properly; if that was the cause of the change in the fan output).
Suspect the problems were mostly related to the HDD over heating. But the high heat exhaust and large fan output occurred mostly when I was charging the battery while using the laptop. Want to avoid that. After the fan output nearly stopped, the scheduling problems became acute. I suspect this is when the temperature control became inadequate for the system. Hope no other problems manifest.
