[SOLVED] Toshiba Satellite gives cooling warning then shuts off
babawren
Commendable
Feb 27, 2018
Toshiba Satellite gives cooling warning then shuts off,,,virus or fixable problem. Won't stay on long enough to do much
Toshiba Satellite... that's pretty old, isn't it? I don't actually know.
If so, the most likely cause is:
-thermal paste finally dried up
-dead fan(s)
-clogged with dust
-all the above
The 1st one is easy enough: get some thermal paste or pads, remove the old paste using alcohol and a disposable soft cloth, and apply the new paste/pad.
The 2nd one, you'll have to check online for replacement coolers. The product ID should be on the cooler itself.
The 3rd one should be obvious enough.
-dead fan(s)
-clogged with dust
-all the above
