Toshiba Satellite P35-S611 & WinXP Home SP2 wireless netwo..
G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
My USR8054 Router has been updated with Version 1.67b44 (125 Mbps Update) - I
CAN connect to internet via ethernet but am unable to connect wireless with
my new Toshiba Satellite P35-S611 Laptop running Windows XP Home with SP2. I
was on the phone for about 3 hours with Toshiba Support Technician (Level 4)
following service call visit by Comcast Technician who attempted to work with
the issue for 1 hour. Windows Patch KB884020-x86-enu and WinsockpFix were
both applied to the Laptop without success. The Laptop has Atheros AR5005GS
Wireless Network Adapter. All security features and firewall were turned off
and still unable to connect. The USR8054 Network is seen with excellent
strength but laptop can not acquire valid IP address under wireless
condition. Toshiba referred me to USRobotics for solution. (Note, thinking
the router was the problem, I purchased a Belkin 54G Model F5D7230-4, Version
3000 with exactly the same results so I believe this to be a setting issue
with the configuration.) Any help would be most appreciated.
G
Guest
Guest
On Wed, 11 May 2005 08:10:02 -0700, "veromay"
Don't know if this is applicable in your situation but I ran into a
similar problem last night, trying to connect to our company's
wireless network in Italy after arriving from Australia.
Turns out the network was set up to require use of proxies, which
wasn't necessary in Australia. Once I went to Internet
Explorer/Tools/Internet Options/Connections/Lan Settings and ticked
"Use A Proxy Server for your Lan" and put in the correct address
(192.168.0.1 for me) and port number (3128 for me), I connected OK.
Nobody knows why the network is set up to require the proxy.
HTH
G
Guest
Guest
The wireless card was replaced and now seems to work better - still a problem
with wireless connection drops however.
> HTH
G
Guest
Guest
I am now able to be connected (although without any WEP) and now this laptop
is taking up to 10 minutes to boot up. I am wondering if there is a deeper
problem.
> > HTH
Similar threads
