Question Tower system power cuts out with a click sound ?
Richard1234
361
5
18,685
Hi,
I built a system based on extensive advice from Aeacus over a year ago, namely https://forums.tomshardware.com/threads/new-build-questions.3836713/
System Specs
MSI ACE mobo
RYZEN 7950X3D CPU
RTX 4060 GPU
Corsair DDR5 RAM
Enthoo Pro case
Prime TX-1600 PSU
Dark Rock Pro 5 cooler
Noctua A14 fans
everything has been fine till now, but a recurring problem has emerged.
I have been doing a lot of backups of mainly 2T magnetic drives, and also verifying the copies are correct, over several days.
some backups can take more than 12 hours. so the machine has been under heavier use than normal for many days.
as I am trying to migrate my storage from USB2 enclosed sata magnetic drives to USB3 drives, mostly magnetic but a few SSDs, eg 5T magnetic USB3 ones, and 4T SSDs, and some 2T and 1T SSDs.
whilst one of some 490gigabytes was verifying, I went for a walk, and returned to find the PC had powered down. the lights on the Corsair ram was on. But I couldnt wake up the machine. Eventually I tried to power it off with the power switch at the top of the the Enthoo and nothing happened. so I powered it off at the mains.
now what happens is sometimes it will boot like now, but at some point there is a click from the machine and the power goes, but the Corsair rainbow lights continue. Other times the power cuts out before it reaches the boot options. It is quite frustrating.
I tried powering off all the USB hubs, as I have three USB3 hubs with 10 ports each, ie 30 USB3 sockets via hubs and more than 20 are in use, but at any time I might just use maybe 4 of those. the others are connected up but are powered off. I have the Sabrent 10 hubs. Items are powered off at the mains switch if mains powered, or at the hub socket switch if powered by the hub. The idea being to minimise attaching and detaching as that wears out the contacts and the hub becomes junk.
and also detached the sata cables to 2 magnetic drives in the tower in case any of these was the cause of the problem. but the problem persists, I can power up sometimes like now, but at some point there is a click from inside the machine and the power goes, but the Corsair memory modules rainbow lights continue. And the power button at the top of the machine doesnt work to power off fully.
I cant determine where the click is coming from.
You might want to narrow your focus to the PSU, that seems to me where the source of the noise is.
For the sake of relevance, what BIOS version were you on for your motherboard? You could try and see if reflashing the BIOS on your motherboard helps. To also add, perhaps remove the discrete GPU and all connected peripherals and see if you can get POST. I said remove to rule out the possibility that perhaps the USB hubs are causing an electrical issue.
Reactions: digitaldata77
Fancy seeing you here again. :)
Most likely the "click" comes from the PSU.
As of why, well, one option is that one of the PSU's protections is triggered and to save the PSU, PSU initializes the full shut down, hence why PC looses power.
It could be that your USB hubs are overloading PSU's 5V rail, triggering PSU's protections.
So, what Lutfij suggested, is a good idea.
Another option is main electricity grid issue.
Now, i can not remember if you also got an UPS to back up your build or not. 🤔
But this much can be confirmed that the build initially worked fine, right? And your issue appeared at some time later?
BIOS Version/Date American Megatrends International, LLC. 1.E0, 28/03/2024
I give further hardware info below at the end of the message
I'll give the info first and we consider options before I try that in case the problem can be fixed at a more outer level. I would like to try the most lightweight remedies first!
this machine is dual BIOS, so I might try switching BIOSes before reflashing, but I'll see what replies on the info so far first, eg to maybe remove the GPU first.
I do have a 1000 Watt Corsair PSU in my earlier PC, RM1000X, where as another option to try substituting the Seasonic with that temporarily to see if the problem is the Seasonic. The Seasonic has a 12 year warrantee.
not sure what you mean by POST
the problem persists even if I switch off all 3 hubs at the mains. where they are still connected to the PC via the USB cables. these are all powered hubs, ie they have their own mains supply and dont draw power from the PC.
I give a link later for the specific hub I use.
could the powered off hubs connected by USB cables cause a problem?
ordinarily I just have 1 hub powered on, the 1st hub has the most frequently accessed items, the 3rd hub has the least frequently accessed items, so I only switch on the other hubs when I need items connected to them.
this also makes it easier to disconnect a swathe of different items with one switch.
the arrangement is so I can connect and disconnect items entirely with power switches, not by physically attaching or detaching cables, as the latter wears out the contacts. I use extenders also to reduce wear and tear ie hub -- extender --- extender --- item, where I only attach and detach extenders.
the USB hubs are the sabrent 10 hubs, which dont draw power from the PC. namely the following which you recommended last year:
Sabrent USB3 10 hub
where each socket has its own power switch, and the entire unit has its own mains cable.
3rd June there was a major power cut, the first in almost 20 years, where the lights wavered and then there was a flash of light and a sound, the power supply firm said it was caused at a nearby road, not by anything I was doing! I saw their van there in the afternoon fixing it, there was no power at all for several hours. The PC was in the middle of a lengthy disk copying op when that happened, so I had to restart that all over again.
but the problem emerged yesterday 8th June, where I had meanwhile done a lot of lengthy backups on Linux, many overnight, with no power loss to the machine as the shell commands were still running in the morning.
the first power cutting out yesterday I was going for a walk so dont know what happened, but the subsequent ones, I didnt notice any wavering of the lights, where usually I have the lights on even in the day as the room is shielded a bit from daylight.
I didnt because long ago, approx 2005 I got a UPS, but when I tried it, I could feel some buzz in the air like there was an ocean of invisible stuff being held back, and I got scared of that and never used it again. I was going to sell it on ebay but when I tested it, found it was defunct, so I had to junk it! I noticed then that the documentation said you had to use it from time to time!
the build has worked since I built it, I think over a year without problem. A few times when I thought it wasnt booting, it was always that the monitor had powered off completely and I had to power it with its switch and then eg the Windows desktop would appear! ordinarily, I only need to switch the mains on for the monitor. but if I leave the computer and monitor running overnight, often I have to also press the integral power switch of the monitor. I did try that with the initial problem, but nothing happened, I tried the mouse, the keyboard, nothing. the mouse light was off also. I detached and reattached it to the USB extender and the light reappeared but wouldnt start the machine.
the power switch on top of the enthoo pro wouldnt wake up the computer with single presses, and where ordinarily a prolonged press powers off the PC fully, nothing happened! I had to use the mains switch to power off. same problem with the subsequent loss of power, but unusually the corsair modules rainbow lights remain on during these problems. that's why I thought it was hibernating. so it doesnt cut all power, power continues to the corsair memory modules.
the system gives the info as:
OS Name Microsoft Windows 11 Pro
Version 10.0.22631 Build 22631
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name ************
System Manufacturer Micro-Star International Co., Ltd.
System Model MS-7D69
System Type x64-based PC
System SKU To be filled by O.E.M.
Processor AMD Ryzen 9 7950X3D 16-Core Processor, 4201 Mhz, 16 Core(s), 32 Logical Processor(s)
SMBIOS Version 3.6
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Micro-Star International Co., Ltd.
BaseBoard Product MEG X670E ACE (MS-7D69)
BaseBoard Version 1.0
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume16
Locale United States
Hardware Abstraction Layer Version = "10.0.22621.2506"
I have a multiplug adaptor on a cable from the wall mains socket, with the PC plug attached to the adaptor, and then 2 multiplug cables from that adaptor, and then cables from the further multiplugs,
in total I have 6 multiplug adaptors with 27 items plugged at all the extended sockets, including multiplug cable plugs, but most will be switched off most of the time.
eg right now what is on is all multiplug adaptors, and monitor, PC, one 10 hub, laptop, 1 USB2 enclosed sata magnetic drive which I am copying at the moment to a more modern USB3 5T magnetic drive (Seagate One Touch which draws power from the laptop's unpowered external hub) using the laptop which will take approx 17 hours to copy as it is 2T and the drive is slower technology, all other of the 27 are powered off. The laptop means I can continue backing up the non M.2 drives.
now could that first multiplug with the PC attached to it cause such a problem, as it is quite ancient.
is it worth replacing that multiplug with a brand new one?
also could the downstream multiplugs cause problems upstream to the first multiplug at the PC's plug?
I think all the multiplugs own plugs are fused.
arrangement:
mains ---- multiplug (with PC,monitor,1st 10 hub,...) ===== 2 multiplugs etc
I suspect your PSU may have suffered damage when the AC mains supply failed in the street outside your home. Uncontrolled high voltage mains transients caused by arcing (as indicated by a bright light) might have zapped the MOV in your PSU or some other component (semiconductor).
Apparently you're losing at least one of the main DC power rails (12V, 5V or 3.3V) so the system stops working. Perhaps your Corsair rainbow lights are fed from the auxiliary +5VSB rail which is present all the time the PSU is receiving mains power with the rear panel on/off switch set to on.
The click you hear from some ATX PSUs is the "bypass relay" associated with a Thermistor (Varistor) in series with the Line input. After the initial high current switch on surge, this relay kicks in and bypasses the Varistor, to increase PSU efficiency (the volt drop across the Varistor wastes heat unnecessarily).
If you have a different PSU from another PC, try substituting it before doing anything else. I'd advise uplugging all your many hubs before doing this, but top marks for using connector savers. I got through several micro-D savers each year at work costing $200+ each.
A thought regarding your powered hubs. There's a vague chance the +5V supplies (from the power bricks associated with the hubs) are feeding back into the computer. This would happen if the supplies are not completely isolated (diode-ORed) inside the hub. You could check with a multimeter, but's not always easy to achieve.
The next time your computer fails, try unplugging the USB connections from all external hubs and drives and see if the Corsair rainbow lights go out. You might be forcing +5V from the USB hub power supplies back into the motherboard and keeping the rainbow lights illuminated. Stranger things have happened.
My personal preference is to avoid using USB hubs, so I mothballed a collection of 11 USB3 desktop hard disk drives several years ago. The 3.5" hard disks (2TB to 8TB) get too hot for my liking (up to +60°C) inside their plastic housings, with limited ventilation and no fans. If you extract the hard disks from WD Elements or Seagate housings and fit them in a desktop PC with direct fan cooling, the same drives run at +30°C to +40°C.
https://www.ifixit.com/Guide/How+to+Shuck+a+WD+Elements+External+Hard+Drive/137646
I feel much happier with nearly all my hard disks running cool inside PCs. A typical Fractal Design R5 case has bays for eight 3.5in hard disks. I have Lian Li cases with room for twelve to sixteen 3.5in drives. Better (to my mind) than a bunch of external USB drives running near their maximum temperature limit.
From 2018 onwards I've been using a couple of cheap second hand LTO4 SAS tape drives to archive files to 800GB tapes. The drives cost $100 each and some barely used tapes were $3 each. With the write-protect tab engaged, the tapes are pretty safe from accidental file deletion or Ransomware. Tapes are nowhere near as handy for fast file retrieval, but they're good for archives.
A USB hard disk is at risk all the time it's connected to a PC attached to the internet. I keep a minimum of 3 copies of all important files on different systems, sometimes up to 6 copies.
Tip.
I use Free File Sync for such tasks. If the copy process is halted or fails, Free File Sync can be used to check the difference between two folders or complete drives and resume file copying without having to start all over again.
All you need to do is Compare the contents of the two folders/drives. I place the Source folder in the left pane and the Destination folder in the right pane, click Compare, then click Synchronize. Easy.
https://freefilesync.org/
With this info, i agree with what Misgar said;
Since you have spare PSU (Corsair RM1000x), swap the PSU out to confirm PSU issue. Also, keep in mind that you have to replace modular power cables as well, that come out from the PSU. Seasonic power cables aren't compatible with Corsair PSUs.
Once you have PSU replaced and build powers on without issues and stays on, i suggest that you RMA Seasonic unit under warranty. You may get replacement PSU cost free.
Moving forwards;
I suggest that you do get an UPS to back up your PC. I can give you in-depth info about UPSes and which one (good one) to buy.
Since main electricity grid issues can happen at any moment without 0 notice, UPS'es job is to protect all the hardware that is connected to it. And when power loss (blackout) does happen, UPS also keeps the PC running for a while, so that you don't loose your unsaved work.
Else-ways, you're gambling again and it would be matter of time when another electricity grid issue comes around and damages your PSU again.
POST = Power-On Self Test.
The initial system test PC does when initially powered on. Before you get a prompt to enter BIOS and before the PC boots to OS.
Reactions: helper800
many thanks for the extensive reply!
I need to digest the info, before I read this I did buy a brand new 6-multiplug, with 2 USB A and 2 USB C sockets today, and put just the PC, monitor and one 10 hub on it from a different wall socket, next to the socket currently used.
after maybe more than an hour in the middle of an email reply, the click happened and the power cut from the PC. I will try that again and then to try your idea of disconnecting the USB hub.
its a bit of a performance to change the PSU, so there may be a delay before I get this completed!
what is the reason for the power switch at the top of the enthoo not working when the power cuts out?
or maybe its what you say in the following paragraph about the corsair getting its power as a backflow from the USB hub
so I will test that idea when it next happens.
I use the Sunguy extenders recommended by Aeacus last year:
sunguy USB 3 extender
because I junked so many USB 2 hubs where the contacts were worn, and eventually all USB2 sockets of my old 2010 PC were unusable! I then had to use a USB3 PCI card to get 2 USB3 sockets!
I first learnt about this problem from a Nextbase dashcam, where I was moving the SD card to and from the PC to access the recordings. and at some point vids were becoming corrupted, eg freezing with a green screen. Then I exchanged SD cards between the 2 dashcams, one at the front of the car, one at the back, and now no problem on the affected dashcam. so realised it was the SD card, and its just the contacts wearing out. if you have a chip and pin credit card, and use chip and pin a lot, the chip becomes seriously worn out and can then stop functioning. Since 2012, cards moved to contactless, but larger payments and every now and then as security they force you to use chip and pin! so now I never remove SD cards and use the USB cable instead. With the Nextbase, I cannot keep an extender as it collides with the fixture on the window. but when it wears out, I can then use the SD card just once! I bought a 2nd hand 3D camcorder recently, and have a permanent extender to connect to a permanent extender on the 3D bluray TV recorder machine, both by Panasonic. It takes 2 x 64GB SD cards, the large format. I use the remote control also instead of the touchscreen to minimise wear and tear of the screen! Pioneer no longer make the dual 3mos 3D camcorders, which have 6 CMOS's so you get super impressive colours, many 3D camcorders use just 1 CMOS for the 6 colour components of the 2 lenses! where they split the image to one sensor, which shares red, green blue.
with my new Samsung smartphone, I only use a magnetic charger, that way no physical wear of any socket. Also I transfer files to my PC wirelessly using Samsung Dex, but today since installing an update, Dex isnt functioning, and instead I transferred a photo as an email attachment!
with the PC in particular I never use the BIOS flashing USB socket except to flash the BIOS because if that wears out, you cannot flash the BIOS again!
would this only happen for things connected indirectly to the same wall socket?
ie 1 wall socket ---- multiplug --- multiplug --- multiplug ... items,
ie are the 2 wall sockets isolated from each other?
this is in Britain, where I have a modern "consumer unit", where its not fuses, but where switches trip if there is a problem, and you just flick the switch back. Older houses have fuses, but I got mine modernised as by law you need the new system for new installations of kitchen electrics. "consumer unit" is probably british jargon.
I will definitely try this, when it next happens.
most of the time I just use the 3 M.2 drives, I only connect other drives for things like backups.
I think the M.2 drives get seriously hot also.
Now I noticed that if I do a major backup of say M.2 drives, the fans come on full power!
so I think its when you access the drives that they really heat up. data is basically hot!
right now the 17 hour backup of a 2T magnetic 3.5" sata drive (WD Blue) in a USB2 enclosure has completed, and it has gone into hibernation! I dont know if the hibernation is from the USB enclosure or the PC or the sata.
I try to make backups to a different disk each time, with the backup disks powered down otherwise.
these are huge backups, eg compressed could easily be 300GB, thus making 2 identical ones is very time consuming.
this actually paid off recently when a 500GB Samsung SSD went completely defunct. And is where I think magnetic drives are more reliable, in my experience magnetic drives slow down before they go completely kaput, where you can salvage the stuff. but this SSD went from everything to nothing, so salvaging not possible.
the USB2 enclosures not so reliable, but maybe the ones I got are low quality ones, there wasnt much choice.
connected to sata it does appear, on Linux you can access a disk as if it is a file, eg /dev/sda or /dev/sdb etc, which you can read off from the Disks program. When I did this, attempts to access it, which require the sudo command, say it has 0 bytes.
luckily I have a sector clone as a file of the entire drive in 2021 which has other volumes also,
and a compressed archive of the main work directory from 2023, where I have only made some tiny changes since then. And I have regenerated the sector clone to a 1T T9 Samsung drive, and later will manually merge the archive with that, I need to study the timestamps to compare the 2 systems to merge them.
had I not been so paranoid about backups I could have lost a lot of my own works!
as regards 3 copies, what I do is archive each time to a different disk. so I have archives going back to 2006 for my work directories, which generally arent huge, as its mostly text based things, and for backups of drives, when a disk runs out of space, I delete the least recent ones of any where there are more than 2.
thus I have copies on different disks, but from different points in time. eg I might have a sector clone of the system drive from May on one disk, and from April on another disk. if I attempt a repair of Windows, I make a sector clone of the entire drive via Linux, because in the old days I didnt, and at least 2 repairs got stuck, where the windows installation became unusable! luckily I never keep work on system drives, as system drives are the most used, as they are used every time you boot the machine, so they wear out first.
I dont know about the newer volume formats, but with say 32 bit Windows XP, the volume format of hard drives begins at sector 0, so that sector gets worn out first! I had a Samsung drive, where the first sector was corrupted and unwritable. I think I could salvage the data, but the disk was no longer usable.
thus emails, photos, text, NEVER on the system drive, I dont use those "Documents", "Pictures", "Music" etc folders that Windows supplies! Always such things to other drives, and backups to drives which are powered down most of the time.
Tip.
does it preserve the timestamps also?
the click happened whilst I was replying to you!
as I could no longer read what he said, I removed the USB3 hub's power socket, where that new multiplug just has monitor, PC and 10 hub connected.
but the rainbow lights continued, I waited many seconds, then switched off the mains to the PC and now the rainbow lights vanished.
afterwards I realised maybe I need to also disconnect the USB cable to the PC, where just 1 extender is used from the PC as the hub cable is relatively long. Next power cut click I'll disconnect it at the extender and at the mains to see if the corsair rainbow lights stop.
then whilst writing this, the power cut out again!
and I forgot to disconnect the USB cable from hub to PC.
this time I am posting from my laptop, with the PC tower booted up to windows 11 on the other table waiting for it to fault. I made a really small table for the laptop, and this laptop and mouse can handle 3 computers, so I can use the same wireless keyboard and mouse for both. one technical problem regarding this is the laptop mouse pad is worn out where clicks dont work properly, which on Linux makes it problematic to pair the mouse and keyboard. The only way out would be to use a wired mouse. Once paired, next session it remembers, but sometimes it doesnt! and it has to be re-paired.
this is what I am dreading!
not sure what you mean by RMA?
I may contact them first before exchanging PSUs, should I volunteer the info that there was the power cut?
or should I wait till they ask?
I wont lie about it, but with businesses sometimes you have to be careful what you say and what you dont say, as they can use either to your disadvantage. Thus often to only give info that is requested. With government officials also its like this, you should never volunteer info, neither positive nor negative.
whereas with this forum I will give all the info I can think of.
if they dont replace it, I may try the house contents insurance,
Moving forwards;
will the UPS protect the PSU from this kind of power cut damage?
as regards the saving, the problem is if the power cut is whilst I am asleep!
as I often backup disks whilst asleep! eg the last backup I did took some 17 hours!
some take 8 hours, some take 3 hours.
thus I may lose some unsaved work!
I often start a command last thing at night, then after breakfast I check whether it completed!
I can tell often also if the hard drive led is flickering that the commands havent finished!
I put some echo commands in the scripts to tell where it reached if a problem, eg
date > markerfile1.txt
shell_command1
date >markerfile2.txt
shell_command2
date >markerfile3.txt
I may be able to tell from the file sizes also if a command completed.
I had wrongly assumed a Seasonic would have its own shielding from this kind of problem.
but it does this test for whose benefit?
if the test fails, does it communicate this to the user somehow?
it is presumably not for the computer's own amusement?
especially with AI!😕
this mobo does have an led with numbers which change continually during the boot, this is where the transparent door is a good idea!
also where it pays to print out the manual! or to have a 2nd pc.
some of my early PCs didnt have transparent sides, so if there was any signal one wouldnt know! I think this is a problem with laptops also!
Since you already assembled the whole PC on your own, replacing the PSU isn't such an ordeal as e.g installing MoBo into PC case and connecting all the needed cables to it. :)
At current moment, we don't know exactly if the fault lies within the PSU (e.g damaged during blackout) or within your USB hubs. To rule out either of the two;
1. Disconnect ALL USB hubs from your PC. Leaving only KB/mice, monitor and power cable connected to the PC.
Could be that one of your powered USB hubs is feeding power back to the MoBo, like Misgar suggested. And while you may have switched it off from the button, it may still feed some power back to the PC (on/off button doesn't work right anymore).
2. Replace the PSU with the spare PSU.
IF the issue is with Seasonic TX-1600, using 2nd, known to work PSU, would instantly tell if issue remains or not.
RMA = Return Merchandise Authorization
Further reading: https://en.wikipedia.org/wiki/Return_merchandise_authorization
It means that you initiate a warranty claim of the PSU and return the PSU to the seller/manufacturer due to the fault PSU developed during the warranty period.
Well, you can describe the symptoms you're having. And you can also disclose that there was a blackout and that probably caused some lingering damage to the PSU.
Though, do note that when you do not disclose that there was a blackout and instead are hoping that Seasonic would replace the PSU for you, Seasonic will put the PSU under testing to figure out why the PSU failed. In this testing, they can find out that external cause (blackout) was the reason of the PSU's failure. And once that happens, Seasonic may or may not hold up the warranty. Since after all, warranty covers PSU's own manufacturing errors, not the external causes that may damage the PSU. (Blackouts, surges, too high humidity, too high/low ambient temperature, improper usage of the PSU etc.)
You need to read your insurance terms and if outside electrical damage to electronics is covered or not (like blackouts, surges due to lightning strikes etc).
Yes, since this is the very job of the UPS.
It really doesn't matter if you're awake or sleep when there is a blackout and PC looses power. Since even when you're awake and sitting behind the PC, you do not have the ability to keep the PC running once there is a blackout. Now, PSU can keep the PC running for a short time during blackout, namely 26.3ms but it is incredibly short time that you can't even register.
1 second = 1000 milliseconds.
Human reaction time is 250 milliseconds for visual, 170 milliseconds for audio and 150 milliseconds for touch.
While Seasonic TX-1600 can keep the PC running for 26.3 milliseconds. (ATX standard specifies PSU hold-up time to be at least 17 milliseconds).
Now, if you would have a proper, good quality UPS. It could catch main power grid fluctuations (e.g power loss) within 2 - 4 milliseconds. Which is more than enough time for PSU to keep the PC running in the mean time, before UPS switches over to the battery backup.
Well, it does have some protections, like the hold-up time, where PSU must keep the PC running during power loss. But PSU does not have AVR in it nor does it have battery for power loss. For that, there is an UPS.
PSU is a device that turns AC into DC and splits it over different voltage rails (e.g: +12V, +5V, +3.3V) for PC components to use.
If all ATX PSUs would protect against all electricity grid issues, there would not exist an UPS in the first place.
It's own benefit, to ensure all the core components work as they should.
Once you power on the PC, these steps are executed in order, before you can log in to Windows;
Direct link if image doesn't load: https://laymentogeeks.wordpress.com/wp-content/uploads/2020/08/rurr.jpg
As you can see, POST is just one of the steps within the chain.
Found this small slide show, where it describes nicely what POST does. Slides 2 to 7,
link: https://slideplayer.com/slide/10137134/
It could, via error beeps or messages on screen. But usually, when there is critical failure, you will not see anything on the screen and PC will not boot to OS. If that happens, one of the core hardware (or all of them) have a fault: CPU, MoBo, RAM, GPU (or iGPU), PSU.
These numbers/letters show what kind of POST tests PC is currently doing when initially powered on.
I think its the idea which is daunting, once I start probably not so bad!
I have to also dismantle the earlier PC a bit to extricate the other PSU!
it does sound like I have no choice but to exchange PSUs,
is there any chance the problem is with the mobo?
or would the PSU catch any problem before it reaches the mobo?
ok, will do this as the next experiment, before trying to change PSUs.
if it is just the hub which is malfunctioning, that would be better!
will try that as the 2nd experiment, as asked above, could the power outage have caused a problem at the mobo?
eg where say hub and PSU are fine, but not the mobo?
with other things they cover "acts of god", eg storm damage to a roof, but they dont cover wear and tear. accidental damage has to be opted into.
I think the power outage is an "act of god"!
my current policy covers damage up to something like £2000 per item, anything above £2000 has to be individually listed and an extra premium is charged for those.
but the UPS presumably supplies the 50Hz 230V voltage?
they must then convert the battery DC to the 50Hz 230V?
is the battery just a normal rechargeable battery, something like lithium ion?
my laptop has a battery I cannot remove, if I switch off the mains it just continues with the integral battery, so in a power cut I think it will just continue, but a surge maybe could cause a problem to its transformer?
what I meant was when the UPS replaces the mains, I would be asleep so wouldnt be able to cleanly shut down whatever I was doing.
how long does the UPS power the PC for?
but maybe a higher end one does!
its like you can buy plug adaptors which shield the user and equipment, but the modern fuseboxes in the UK shield at the fusebox ("consumer unit"), eg with a hedge trimmer by accident I cut the power cable with the hedge trimmer, and there was a brief orange flame and a sound. The consumer unit switch had tripped, I flicked that back. I had cut the extender cable not the integral cable, and when I connected the integral cable to the mains, no problem!
the consumer unit shields both the person and the equipment, I just wonder if it would shield the computer's PSU?
I have uploaded a photo of the consumer unit:
consumer unit
I think the multiplugs with the PC etc are from items 3 or 11,
when they install that, they have to test all circuits and forward the certification document to some governmental authority, probably local government. And to give the customer a copy of the certification. when the guy did the testing, he located a missing circuit, which we eventually found which was a nonstandard arrangement.
very interesting image! I was dabbling with 2 specific early phases of that for 32 bit PCs, where I would boot code directly from a floppy, which would be the stage one boot loader in that diagram and none of the steps beyond that, and I wasnt aware of the steps before that! where I was just at steps 7 and 8, if you answer no to the first question step. I wasnt aware of the other steps of the diagram, I would generate the floppy from a Windows command prompt using 16 bit BIOS code, to load the code to the floppy. then reboot from the floppy disk. I think the 32 bit windows command prompt has an emulation of the BIOS.
my guess is I could put that kind of code on the first sector of a CDR in this era, and boot from that? or the first sector of a hard disk dedicated to the experiment.
the code on the first sector of the floppy then via the BIOS would load further code from the floppy and execute that.
my code written for an old era floppy disk, would work from a USB floppy also, where the BIOS emulates an old era floppy from the USB one. ie no USB commands needed.
do you have any links to the programming environment for todays 64 bit PCs for stage one? have they replaced the old BIOS with some new kind of BIOS? maybe a 64 bit BIOS?
eg the mobo early startup has a mouse pointer and graphics imagery, that isnt possible with 16 bit! as there isnt enough memory for one proper video screen, instead they used tricks, where 1 byte will encode a font character on the screen.
1 HD screen is some 2 million pixels, not viable from say a 32kilobyte 16 bit machine!
with the 32 bit PCs, you have a 16 bit environment much like the PC was in 1980, where I used info from a bygone era, the code then if it wants can promote the CPU to 32 bit, using supervisor level commands, and then with the 32 bit code use supervisor level commands to promote to 64 bit. But I think they have changed this for todays PCs, as you cannot install 32 bit windows. so maybe stage one is immediately a 64 bit environment?
is there any way to pause that slide show?
as it rushes to successive slides before I have completed reading any!
if I read it at that speed, I wouldnt have time to understand what I have read!
If you're asking why do the Corsair rainbow lights stay on, it could (as I explained earlier) be due to their being "back fed" from an external 5V USB power supply, outside the computer. You really should disconnect all external USB leads with the exception of a keyboard and mouse, for the tests to remain valid.
I have known (and dissected) failed mains on/off switches in ATX PSUs. Sometimes the contacts weld shut, so even if you think you've set the power switch to off, the PSU remains connected to the mains. Highly unlikely but these switches don't have an infinite life time when abused.
All of this theorising is academic. Disconnect all USB devices apart from keyboard and mouse as advised by @Aeacus and that will preclude any 5V "back feed". If the fault persists, swap the PSU and all associated modular leads. Even in my systems with 12 hard disks, I can perform a PSU swap in 15 minutes. No need to tidy things up, until later.
Of course if you've Ty-rapped all the PSU cables to the chassis and routed cables behind the motherboard tray it might take a bit longer.
There's no need to rip everything out and undo all your hard work. Just unplug all the leads from the old PSU to the mobo, GPU, SATA drives, fans, etc., and connect the new PSU leads in their place.
You can leave the new PSU (safely) propped up somewhere outside the case and power on. If you're concerned, run an earth strap from the back of the dangling PSU to the chassis to provide a safety earth for the case.
No. The RCD/ELCB is there for your protection. It senses a discrepancy of more than 20 or 30mA flowing back down the Neutral, compared with the current flowing in to the house on the Line input. If more than 30mA is diverted and flows through your heart (if you touch a live wire) you're likely to die.
A UPS might buffer an ATX PSU from damage, but probably only if it's a more expensive double-conversion always-online UPS.
https://www.electricaltechnology.org/2020/05/difference-between-online-ups-offline-ups.html
Standard cheap UPS route the AC mains straight through to the computer via a set of relay contacts. Any disturbance on the mains will arrive at the PC with minimal filtering. If your mains is hit by really short fluctuations, e.g. high voltage spikes, the UPS might not start the inverter and disconnect the PC from the outside world before the disturbance disappears.
It is to be hoped that a good UPS will switch over to battery power in less than 10ms and if your ATX PSU conforms to the 17ms hold-up standard, you should be OK. However, until the UPS toggles the relay over to inverter output, the PC could still be subject to mains disturbances, which in extremis, might damage the PSU. It might only be a matter of milliseconds, but if there's enough energy involved .......
A double-conversion always-online UPS turns AC mains into DC and charges the battery (as does a cheaper UPS) but this type of UPS runs the inverter all the time (unlike a cheap UPS). The inverter feeds the PC with an isolated (hopefully clean) mains supply, which is isolated from transients on the AC mains supply to your home.
Nothing is 100% perfect. I've had two lightning strikes near my house and both resulted in equipment damage. Dead broadband routers, hardware firewalls, associated Gigabit switches, telephone answering machines, etc. Houses in a nearby estate had TVs blasted off the living room walls. No UPS will protect from this kind of electrical disturbance.
I've switched from telephone line and cable broadband to optical fibre-to-the-premises internet, so that's one less avenue for lightning attack. All my problems were conducted into the house via underground cables, metal gas pipes and water mains. None of the TV, FM antennas and satellite dishes on my roof were struck.
The only UPS I've encountered that would hold up your system for 17 hours, was used to power hundreds of servers and workstations in a very large establishment. Its job was to keep everything vital in the building running for 10 seconds, before the 500MW diesel generator outside kicked in. There were rooms full of huge 6V batteries and racks of inverters.
A standard UPS will keep your system running for just a few minutes, maybe longer if it's not providing full rated power. In theory this gives you enough time to shut down the system gracefully (either manually or automatically) without corrupting Windows, but forget any hope of completing a backup.
Don't count on a UPS lasting than 20 minutes, unless you're prepared to spend big money. A cheap UPS designed for a single low-power (office) PC might last only 5 minutes when the mains fails.
I'm running a 1500VA APC UPS which cost roughly £600. It contains two 12V 9Ahr batteries. Smaller UPS come with a single 12V 7Ahr battery. I can run 3 PCs from my UPS, plus a bunch of networking gear, but not for very long when the mains fails.
The (optional) Ethernet card I added to the UPS signals each PC via the network when the mains fails and can launch the Windows automatic shut down process. If I'm in the middle of any tasks, it's a race against time to close down open files in a state of controlled panic. Any long video transcodes (up to 36 hours) just die.
If you want faster backups, you'll have to rethink your backup strategy and possibly spend large sums of money.
I'd hazard a guess most of my eleven USB3 desktop hard disks are SMR (Shingle Magnetic Recording). I can't be bothered to check because I've stopped using them. Too slow and too hot.
SMR disks are bad news for anything apart from slow archive jobs. If you use SMR disks frequently and delete lots of files, they bog down with appallingly slow transfers. They're also bad news in my TrueNAS servers.
https://www.howtogeek.com/803276/cmr-vs.-smr-hard-drives-whats-the-difference/
For the last ten years, I've checked very carefully before buying any new internal disk drives, to make sure they're CMR/PMR and not SMR.
I've got two 8TB Toshiba 3.5" CMR disks in a system and the transfer rate starts off at 250MB/s at the outer cyclinders, falling to 120MB/s at the innermost. This means writing large files (50MB+) is relatively fast. Try this on a heavily fragmented USB3 SMR disk and I'd expect perhaps 20MB/s to 40MB/s.
For truly fast backups (up to 800MB/s) from M.2 NVMe, I use portable SSDs (4TB Crucial X6). The X9 will run at 1050MB/s max and the X10 at 2100MB/s max. Not cheap, but much better than hard disk.
The next time you run a backup, check the transfer rate (for large files). Ideally it should average 100MB/s or faster. Zillions of small files will slow down any sequential file backup. For that reason I use WinRAR to generate huge repositories, before backing up to LTO4 tape, which needs a constant 80MB/s.
ok, I started this experiment just now, with hubs fully disconnected, but with 3 USB drives directly connected to the PC .
I know you said to disconnect all USB devices, but I need some USB drives connected directly to the PC to do a more punishing experiment. But no hubs at all, neither via USB cable nor via mains.
where its like this:
I noticed that when I doubly removed the 10 hub, ie both removing it from the mains, and removing the USB cable to the PC, that the PC seemed to remain on without problem.
so I have now got one brand new multiplug with 3 things attached:
PC, monitor, and a USB2 enclosed sata magnetic drive 2T, no hub
I then have the above magnetic drive and another USB magnetic drive which isnt mains powered a one touch Seagate 5T, both just attached via extenders to the PC.
then I have run Linux from a flash drive also attached via an extender to a PC USB socket.
so 3 USB drives, all directly connected to the PC USB sockets via extenders, no hubs,
just one drive mains powered.
and now from Linux I am doing a lengthy op, which is to do a sector compare of the 2T cloned sector file on the 5T drive with the sectors of the 2T drive.
creating the cloned file took some 17 hours, so I expect comparing could take 17 hours,
there is a progress indicator also, in case it takes too long!
if it completes this, then I think the problem was the hub, and I have to junk that, and buy a new hub.
I started it at 15:37 and it has completed 33664 MB so far at 15:52,
I hope its just the hub, then no problem with the PC or PSU, but I dont make any assumptions.
now in fact it is the USB3 drive which has failed! where the file compare has had the drive run out of bytes early.
so I will power down, move the sata magnetic drive from the USB enclosure to a sata bay, and start again!
there will then be just 2 USB drives, a Samsung 256G flash drive, and a 5T Seagate one touch, both are powered from the USB sockets of the PC, not from the mains and not from hubs.
I am not familiar with this CMR/PMR and SMR terminology
I wasnt aware that the rate changes with the radius. with CDs, the data is in a spiral starting at the centre, and there are 2 mechanisms: CLV = constant linear velocity, often used for recording, where the speed under the head is always the same. and constant angular velocity, CAV, where the disk rotates at constant speed, often used for reading. I was told this by email by a guy who had worked at Philips on their CD technology.
as its a spiral, the data speeds up as you move outwards for CAV, hence optical disks will say eg 1-6X. blurays use a blue laser, whereas CDs use a red laser, hence "blu-ray", and as blue is a much higher frequency than red, much more data on a bluray. I learnt this from an advert for blurays!
Now I had thought magnetic disks werent a spiral, and were constant speed, is this incorrect?
when you say MB/s, is that megabits or megabytes or Megabits or Megabytes?
some of these Samsung drives I think MB/s means megabits per second! as the speeds concur with that! eg 560MB/s in fact is 70megabytes/second.
can be worth spelling out which you mean to avoid ambiguity
I moved the magnetic drive to a sata bay, began the file comparison, but it ended early then I found in fact it is the sector clone at fault! it is just 38.3 gB. There was no error from the shell command when I did it, so I just assumed it had succeeded, and it did take 17 hours.
so I have changed the experiment to cloning the entire drive again to a file on the 5T magnetic USB3 drive
the 2T magnetic drive is now in a sata bay,
just 4 USB items directly connected to the PCs USB sockets via extenders:
keyboard
mouse
one touch Seagate 5T USB3 drive: power drawn from the USB socket
Samsung 256G USB flash drive to launch Linux
if the PC does fail, I will then have to concoct an experiment with just the keyboard and mouse as USB items.
started this at 16:45 UK time, and it is copying 104 mB/s, where I use m to mean 1000000 and M to mean 1024 x 1024, similarly G means 1000,000,000 whereas g means 1024^3.
B means byte, b means bit, so MB = 1024 x 1024 bytes, and mB = 1000000 bytes
Windows uses this notation, but Linux uses M to mean 10^6 and Mi to mean 1024^2, Linux also uses G and Gi similarly.
if that does succeed, I may just junk all 3 USB hubs, and buy new ones as I dont remember which were connected during the power cut.
As it currently stands, would it be safe to assume that you found your culprit?
Good/great quality PSUs - yes (like your TX-1600). Low/crap quality PSUs are so poor that when those act up, they fry other components as well.
Actually, the lower the PSU's build quality is - the higher the chance that PSU fries something else when PSU acts up (be it on it's own or due to main electricity grid issues).
This would be the worst case since replacing a MoBo is very tedious + then some.
But looks like you've found your culprit and the rest of the PC is fine. :)
Power lines are man made objects. And any issues with electricity, isn't act of god. Natural disasters (earthquake, floods, forest fires, tornadoes, flash freeze etc) are act of god. At least this is my understanding. You need to read your insurance terms to see what is covered and what is not.
You can pause the slide show and look at the images one-by-one with the slide show control buttons, just below the slides. If you pause it, it does show the next slide but then stops. You can then use the forward and backward buttons (next to play/pause button) to browse through the images at your own pace.
No.
The PSU what you have, Seasonic PRIME TX-1600, is one of the best (if not the best) PSU money can buy. Yet, it doesn't have internal battery in it, to keep the PC running when there is power loss. For that, you need UPS with dedicated battery.
My knowledge is better than the average but not in-depth. So, no links to share.
I'm jack of all trades, but master of none. Though oftentimes better than master of one. :)
Yes. Though, there's more to that actually.
Misgar already explained some about UPSes, namely online vs offline topology, but there's more;
In my opinion, every PC should have an UPS. :)
UPSes can output 3 different kinds of waveform:
1. square wave - cheapest of the three. ONLY good for robust hardware, like power generators and motors.
2. simulated sine wave (aka stepped-approximated sine wave) - mediocre price. Good for most home appliances (e.g fridge, washing machine, lights).
3. true/pure sine wave - high price. It is the same as you get out of the wall socket. ONLY waveform good for sensitive electronics, like medical equipment, TVs, PC PSUs.
So, you want to have true/pure sine wave UPS. Simulated sine wave UPS may also work, but it may not. More of that below;
When looking for an UPS, there are 2 things to look out:
1. Output waveform (square wave, simulated sine wave and true/pure sine wave)
2. Design (stand-by, line-interactive and online)
From here you can read about the differences between output waveform,
link: https://suvastika.com/why-choose-a-sinewave-inverter-ups/
And here are explanations about the UPS design,
link: https://www.eetimes.com/document.asp?doc_id=1272971
Waveform and design
For PCs, line-interactive UPS would be more than enough since PSUs can easily handle the 2ms to 5ms transfer time of line-interactive UPS.
As far as output waveform goes, true/pure sine wave UPS is best used. While simulated sine wave UPSes are cheaper than true/pure sine wave UPSes, PSUs with Active PFC aren't compatible with simulated sine wave. You might get simulated sine wave UPS running with Active PFC PSU but there can be some major issues. Here's what, how and why.
How do you know which PSUs have Active PFC and which ones don't?
Simple, every PSU that has 80+ certification (e.g 80+ Bronze or 80+ Gold) has Active PFC.
What is Active PFC?
Further reading: https://en.wikipedia.org/wiki/Power_factor#Power_factor_correction_(PFC)_in_non-linear_loads
What can happen when using simulated sine wave UPS with Active PFC PSU?
When simulated sine wave UPS switches over to the battery power, one of 3 things can happen:
1. UPS displays error resulting PC to shut down immediately.
2. UPS shuts down resulting PC to shut down immediately.
3. UPS switches to battery power resulting PC to power off from UPS (PC stays on).
Why it happens?
Simulated sine wave UPS produces a zero output state during the phase change cycle resulting in a power “gap”. This gap may cause power interruption for active PFC PSUs when switching from AC power output to simulated sine wave output (battery mode).
What to do next?
As stated above, your PC can run off from simulated sine wave UPS but be prepared when you face issues with it. When issues do rise, your best bet would be returning the simulated sine wave UPS and getting true/pure sine wave UPS. Or you can go with true/pure sine wave UPS off the bat.
Wattage
As far as UPS wattage goes, you need to consider the power draw of your PC and monitors. Maybe speakers and wi-fi router too if you plan to plug those into the UPS as well. Though, printers, scanners and other such hardware (full list on your UPS manual) don't plug to the UPS since their startup power draw is way too much for UPS to handle and you can fry your UPS.
Usually, taking PSU's max wattage as a baseline is good idea since it will give your UPS more headroom and you can get longer runtime out of your UPS. But since your PSU is 1600W, (over-provisioned with wattage since back then, you were unsure if to go with RTX 4090 or not), there would be no need to look for ~2000VA/1600W UPS. Because the max load on your PC, with RTX 4060, would be ~300W. So, smaller UPS would also suffice.
Good UPS brands to go for are CyberPower, TrippLite and APC. While there are other UPS brands as well, those three are the best out there.
Note: The more powerful UPS you have, the longer UPS can keep your PC running before it's battery is empty.
Yes.
Depends on the UPS. But since battery in UPS is big, it is usually sealed lead-acid battery and rechargeable (essentially the same battery as in your car).
Proper UPS (e.g line-interactive topology) has AVR (Automatic Voltage Regulator) in it. It catches the surges and brownouts before feeding the power to the PC, when PC isn't running off from battery power.
E.g CyberPower CP1600EPFCLCD-UK 1600VA/1000W UPS would be good UPS for your build,
specs: https://www.cyberpower.com/eu/en/product/sku/cp1600epfclcd-uk#specification
It is line-interactive, true/pure sine wave, offline UPS. And successor model of the UPS that i have in use with my PCs.
From UPS specs, you can read what kind of protections it has.
Completely depends on the battery size it has.
E.g the UPS i linked above, and with 300W load, it can keep your PC running for 19.6 mins.
Though, UPSes come in varying battery sizes. Standalone UPSes are up to 3kW (3000W). But server park UPSes are modular and expandable essentially infinitely.
Offline UPS will blare it's alarm like no other, when there is main power loss and PC runs off from battery power. So, when UPS has enough runtime for you to wake up, make it to the PC and shut it down, you'd be good using offline UPS as well.
True, but when one would be looking for online UPS, delta-conversion topology would be better than double-conversion topology due to the better efficiency.
A simple way to understand the energy efficiency of the delta conversion topology is to consider the energy required to deliver a package from the 4th floor to the 5th floor of a building as shown in Figure 7. Delta Conversion technology saves energy by carrying the package only the difference (delta) between the starting and ending points. The Double Conversion On-Line UPS converts the power to the battery and back again whereas the Delta Converter moves components of the power from input to the output.
Source: https://www.eetimes.com/the-different-types-of-ups-systems/?_ga
True.
Depending on the needs, you either look for offline, line-interactive UPS, or online, double/delta-conversion UPS.
There are pros and cons for both;
Offline, line-interactive UPS
* Cheaper to buy.
* Cheaper to maintain.
* Lasts considerably longer.
* Quieter.
* More efficient.
* Shorter runtime (usually 5mins, but when load on UPS is small and UPS has big battery, then ~20mins or so).
Online, double/delta-conversion UPS
* Far more expensive to buy.
* More expensive to maintain.
* Lasts as long as the batteries does. (When failed batteries are replaced with new ones, then lifespan is essentially unlimited.)
* Loud.
* Low efficiency.
* Essentially unlimited runtime.
For online UPS, the batteries in it are in constant use and will wear out much faster. Due to that, online UPSes have several (dozens or even hundreds) of batteries. So that when one or two batteries fail, they can be replaced without interrupting the power source to the hardware. And battery replacement is done by the technician that you call on site. Online UPSes do not have user-serviceable batteries. And since batteries are in constant use, they need to be cooled and cooling of batteries via server fans is loud.
But main advantage of online UPS is, that power supply will not be interrupted no matter what.
These kinds of UPSes are used usually in server parks, where server can not loose power.
Offline UPS is used usually in home environment, since they are smaller, cheaper, quieter and can have user replaceable batteries (like the CyberPower UPS has i linked above). Also, they last a long time since battery in them is in use only when the supply of main power goes out and for the 5-20mins when you safely shut down the PC.
Now, if blackout lasts for few mins, offline UPS is more than enough, since when blackout appears, UPS switches to battery power. But when main power is re-established, UPS switches back to the main power and charges the battery to full again.
Tough part is, that we don't know how long of a blackouts you'd be getting. If it is more than 1h, then offline UPS can't keep the PC running in the mean time. For longer runtime, it is better to look towards gasoline/diesel powered generator, that supplies power during blackout.
so far so good!
3 hours ago I started the cloning of the 2T magnetic WD Blue drive from the sata bay to a 5T one touch Seagate USB3 drive which takes power from a USB socket on the PC, and that has now copied 1tB (using my notation, Linux gives this as 1TB), and is progressing.
and thus also should take about 6 hours.
thus so far it looks like the 10 hub is the culprit!
this is where buying the cheapest options is often a false economy, ie you end up paying more money.
generally speaking the more important something is the more money I will put for a higher quality item.
but I take into account all aspects, eg with cars in Bristol the bigger cars wont fit in the main parking bays, so a Tesla or a 4WD will be a hassle, as tricky to get out of the vehicle in town!
so far it seems that way.
there was a flash of light, so it might be lightning or something. although the power line is man made, the wrecking of it is wasnt man made! presumably thor!
anyway if it is the hub, then the insurance probably isnt any use because of the "excess" (ie the initial amount I have to pay myself on any claim)
ok, that is what confused me, as I expected it to halt on the current slide.
No.
I probably have to ask in an assembly language forum! I will delay for the moment as I can only work on one project at a time. But I would like to eventually make a CD which boots directly and does a bit of stuff with the hardware. From your chart and what I did with 32 bit, I think the hardware will check if the first sector of the CD has a bootable signature, if yes it will load that into memory and start executing the code outside the signature. But I would need to know what facilities are around for the code, and what mode the CPU is in, probably 64 bit, also is the MMU all set up or partially set up or other. There was some word you used to describe the new boot environment versus old era.
Waveform and design
What is Active PFC?
Why it happens?
What to do next?
Wattage
we have a UK specific thing which is energy monitors from the electric and gas boards, which tell you your natural gas and electricity usage right now, where in the UK we have mains natural gas, which eg Germany and the US dont have, americans have to buy the gas canisters, and germans use oil tanks for heating.
but most UK houses have mains gas (methane or ethane, I forget which, from the North Sea oilfields) for central heating and cooking, electricity also for cooking, eg I have 2 natural gas hobs and 4 induction hobs. so with the power cut, no microwave, no oven, no induction hob, no PC tower but the laptop on its own battery, but I could cook with natural gas! but no lighter for that as it draws from the mains. luckily I had a box of matches!
no central heating also as the natural gas needs a pump!
anyway, at night when the solar panels are off, the energy monitor tells me the total power right now of the entire house. eg if I switch off a fluorescent light, within some seconds the power goes down a notch, then switch it on and it goes up a notch. I think ordinary use of my 2024 PC and the entire house uses less than 200 watts. with my 2010 PC it generally used 250 Watts. During the day, the house draws power from the solar, and the energy monitor shows the house net exporting to the grid so I dont know what the house is using. The UK brought in smart electricity and gas meters, where they send the electricity and gas usage directly to the supply companies using the mobile phone system, so they no longer need to send someone to read the meters. They then combined this with energy monitors.
they just send someone to read the water meters still.
after sunset, which here is after 9pm, could be 10pm, I'll see what it says. in the winter at this latitude the sun sets around 4pm, in the summer around 10pm. Maybe I'll upload a photo of it also.
my printer is in another room accessed by wireless! its a huge A3 printer so not viable to put it in this room!
I have an A3 scanner also, which is in this room, only powered on when used. eg its useful for say scanning an entire newspaper page. I have also a 7200 dpi 35mm film scanner, mostly for scanning Kodakchrome films taken by my parents.
ordinarily I think the entire house with the computer on is less than 200 Watts, but with some disk copying the fans come on like some kind of gale. maybe I'll check the energy monitor when that next happens, if I remember to!
Yes.
are there any things which can go wrong with lead acid batteries to be cautious about?
that would be useful, I can then run to the other room with the computer and shut things down in an orderly fashion.
True.
* Cheaper to buy.
* Quieter.
Quieter is a key criterion for me,
noisy computers gradually will drive me insane! I think not good for the ears also, as could cause partial deafness to the involved frequencies.
this is why I only use magnetic drives for long term storage, for work I use SSDs or flash drives, as totally silent.
eg the Samsung T9 and T7 ones, small fast silent!
magnetic drives are cheaper and larger and slower! and probably safer storage.
* More efficient.
can you state the runtime maybe in joules?
its a long time since I did physics, but I think Watts x time = joules, so
eg if the computer uses 200 Watts, then 1 hour is 60 x 60 x 200 joules = 720000 joules.
the lengthy backups will just have the PC and the accessed external drives on. no scanners or loudspeakers.
the laptop will only be on if it is doing the backup.
* Loud.
loudness is the deal breaker!
* Low efficiency.
it sounds like a quagmire! only viable for a business or organisation or institute,
it sounds like the only option for me.
have you considered using optical disks?
these are pretty safe and BDR are undeletable, and really cheap. eg in the UK I can buy a BDR for about 56 pence, which is 25Gig, so that is £22.40 for 1Terabyte.
you can throw a BDR in a river and it should be fine!
I have a BDR-X13EBK Pioneer optical drive which can write to triple layer optical disks which are 100GB read write, called BDXL, I had to buy them from someone in Japan on ebay, factory sealed but second hand.
cost me 118.27 for 10, ie £11.83 for 100Gig, so that is 118.27 for 1TB, not as good value for money as the BDR, but they are rewritable.
I think it does Quad layer 128GB disks, but write once only,
I mainly use the BDRs for transferring TV programs eg top of the pops rebroadcasts to blurays, but I sometimes use them to make permanent backups of computer things.
Like with everything else, there are,
further reading: https://www.safework.sa.gov.au/work...re-to-hazardous-chemicals/lead-acid-batteries
Now, battery is inside the UPS, well grounded and only thing you need to do, is keep about 5cm space around UPS free, for UPS'es ventilation (proper distance listed in UPS manual). Since for offline UPS, only danger would be it overheating when you have blocked it's vents.
Other than that, consumer grade offline UPSes are safe.
From Downloads page and under "User's Manual" section, you can download UPS'es manual and read it beforehand,
link: https://www.cyberpower.com/eu/en/product/sku/cp1600epfclcd-uk#downloads
This way, you get an idea what kind of animal UPS is. :)
And on the Videos tab, there are several nice videos that describe what UPS is, how it works, what power problems there are etc. There is also product preview video.
Link: https://www.cyberpower.com/eu/en/product/sku/cp1600epfclcd-uk#videos
Here is the runtime chart of the UPS i linked earlier,
link: https://www.cyberpower.com/eu/en/product/sku/cp1600epfclcd-uk#runtime_chart
Since it displays it only in watts, this is what i can give to you.
as it stands it looks like the USB hub was the culprit!
I kept the machine on continually from yesterday till today without problem, running Linux
to firstly clone the 2T WD Blue drive via sata to a 5T one touch Seagate, where that went from 16:45 to 23:16, and then same session before going to bed I did a verify from 23:36 till 5:25, where I woke up hours later to see where it had reached and no problem.
so it was on for more than 12 hours, no problem, with no hubs attached, neither by USB cable nor via the mains.
I think the problem in fact was from the USB cable, as earlier when I switched off the hub but where it was still attached via the USB cable, the problem would occur. I dont know if that makes sense that it could be via the USB cable from the hub?
ie the problem probably isnt the USB cable, but it goes from the hub along the USB cable to the PC.
I have to junk that main hub, but I will keep the usb cable, I dont know whether to test the other 2 or if its better to not risk the equipment and junk all 3, and buy anew?
the problem one is the main one, which was virtually always on when I used the computer, eg it has extenders to the main drives I use, so if I just power on one of those drives it will appear on Windows or Linux without further actions.
when doing all this, I need to reconfigure the early startup with a wired mouse, and the existing one is becoming problematic, and I may need one for the laptop also to pair the wireless mouse with Linux, as the laptop mouse pad clicking is problematic, I often need to remove the existing pairing to re-pair, and the mouse pad button click is problematic to get the Linux menu with "remove". to then scan again.
I dont know if anyone can recommend a reliable wired mouse, there are a jungle of different ones, and I think most are rubbish!
with the current one with the Ace mobo early startup, when I try to select boot drives, the mouse pointer flits around the place and its like a game of darts to select a boot option! I only know for sure when I exit the startup and it then says the selected boot option for confirmation.
looks like its not a precise amount of joules, namely a specific graph point to multiply watts by time in seconds, that would be the amount of joules,
at 188Watts, that graph says I will get more than 31.5 minutes. with time, the drives I use will get more efficient, as all these firms are making their stuff greener.
it is maybe dissipating continually or inefficiencies such as heat and unintended emr.
there was some guy who said he notes the joules or calories on his rowing machine, then when he wants to eat some junk food he calculates how much time he would have to spend on his rowing machine to burn off the calories, and usually that is enough to put him off!
if I did go for one of 1600Watts, what kind of price is that versus for the 1000 Watt one?
I know you said 1000 is sufficient, but if the price isnt much higher I might as well overspecify
BTW I tried out the energy monitor well after sunset, with the PC busy cloning the magnetic sata 2T to the sector clone file on the 5T one touch, and with the fridge switched off, all lights switched off, with the only electricity usage being the PC, the energy monitor, and maybe some small amount by the central heating which wasnt running, the entire house was using about 188Watts. see photo:
power usage of entire house at 187Watts
on switching things back on, the power went above 500, so the fridge uses quite a lot.
the energy monitor is very reliable as the electirc and gas billing is based on it, so it is identical reliability as the modern electronic electricity and natural gas meters, I had those modernised a few years ago. the old era ones were mechanical. the monitor just links wirelessly to the meters data feeds to the energy company.
I wanted to upload a photo using Samsung Dex, but after the latest "AI" update of the Samsung Ultra 24, everything has gotten worse! and Dex no longer connects to my PC! so called progress!
I was delaying that update because it said AI, and looks like my scepticism was well founded!
so instead I had to email the photo to myself from the smartphone, and that took 10 years (I time travelled back to 2015 to get the email here quickly! 😳)
AI will always be dubious as there is a maths logic result which says you cannot fully specify an infinite set with a formal system, in particular you cannot even fully specify the integers, so AI as a formal system is doomed. it will always make blunders. historically they tried to specify the integers with the Peano axioms, but those arent a proper formal system, but are some kind of metalevel specification. The Peano axioms cannot be computerised. pure maths is based on set theory which is a conjectured model for the axioms, but the logic result says there are lots of different models for the same theory!
Problem most likely is the USB hub, rather than the USB cable between the hub and PC. Since the USB cable i linked to you back then and which you've now linked to us again, is just a pathway. A cable where electrical current can flow in either direction. From PC to USB hub and from USB hub to PC. USB cable itself doesn't generate any power. It is just a conduit.
So, most likely, the USB hub itself is faulty, where the power on/off button doesn't work anymore, by letting some of the +5V to bleed through the switch, to continue on to the PC. And PSU catched the +5V rail going out of spec, thus shutting down the entire PC.
Depending on how old they are.
But i'd replace them all, if they all are same make/model. Since it would be just matter of time when other two would act up as well.
Well, since mice are in constant use, they wear out fast as well.
In my time, i've had several Corsair "gaming" mice in use and i've came to learn model specific issues.
Corsair Sabre RGB (EOL now) - will develop double left click fault within ~1 year of usage. (Has happened to 3x mice i've owned.)
Corsair Nightsword RGB (specs) - will develop middle mouse button (scroll wheel) click down issue within ~1 year of usage. (Has happened to 2x mice i've owned.)
Now, my current mouse is the Nightsword RGB and since i use the middle mouse button a lot (to open/close browser tabs), the button eventually works sporadically until completely stops working. But the scroll up/down still works fine. So, if you do not use middle button click heavily, it actually is quite durable.
In-depth review: https://www.rtings.com/mouse/reviews/corsair/nightsword-rgb
Nightsword RGB is expensive mouse, since it has plethora of features, where most of them would be useless for you (some of them are even useless for me).
Those features include;
* dedicated control software (Corsair iCUE)
* several buttons (8 programmable, 10 in total)
* ARGB eyecandy (4 different zones)
* thumb rest
* sophisticated weight calibration (up to 120 different weight and balance configurations, thanks to 2 sets of weights and 6 mounting locations)
* real-time center of gravity detection system
* 18000 DPI optical sensor
* Omron switches (rated for for 50 million clicks)
* selectable polling rate (125Hz, 250Hz, 500Hz or 1000Hz)
* on-board memory storage (to store custom profiles)
* wired connection (USB 2.0 type-A)
All that, for 66 quid (as a sale);
Amazon UK: https://www.amazon.co.uk/Corsair-NIGHTSWORD-Gaming-Mouse-MOBA/dp/B07RJ1678R?th=1
For you, i suggest you look something else, since there's no point for you to pay extra for most (if not all) of those features it has.
E.g SteelSeries Prime or Logitech M100/B100,
further reading: https://www.rtings.com/mouse/reviews/best/by-type/wired
There are no CyberPower UPSes in the PFC Sinewave series that are 1600W. The 1000W one is the beefiest in that series. So, you need to look towards different series of UPS, if you want 1600W one.
1000W UPS costs 320 quid,
amazon UK: https://www.amazon.co.uk/Cyberpower-CP1600EPFCLCD-UK-Sinewave-1600Va-attached/dp/B0D97R82VC
200W load runtime is 31.5 mins.
Closest one to 1600W would be Smart APP UPS series, professional tower 2200VA/1980W,
specs: https://www.cyberpower.com/eu/en/product/sku/pr2200elcdsl
And costs 685 quid,
amazon UK: https://www.amazon.co.uk/CyberPower-Professional-Tower-2200VA-Interactive/dp/B00VHL2LGC
It too is line-interactive, true/pure sine wave with user replaceable batteries. But much bulkier and doesn't have UK plug output, instead one IEC C19 and 8x IEC C13.
Runtime wise, 200W load lasts for 75 mins.
I bought 2 around a year ago when building the new PC, and the 3rd one a few weeks ago when I ran out of sockets, as I had 20 devices, but one drive needed 2 USB sockets with one for power,
I just hope a brand new one doesnt fail because something at the PSU is damaged?
but when I reused the hub sockets for drives yesterday, no problem.
* thumb rest
maybe then it is just worn out,
note that I just need a wired mouse for the early startup and also to pair the wireless mouse.
I have a high end wireless handshake mouse, the Logitech MX Vertical, where you hold the mouse as if giving a handshake, super ergonomic:
handshake mouse photo
which has a 3 year unlimited replacement guarantee from the shop, any time it fails, they will replace it immediately, no limit how many times.
it cost me about £100, then when I actioned a replacement they gave me a £40 voucher, because it now only cost about £60! where they replaced it by refunding and then re-charging, so they refunded 100 and now charged 60, and gave me the surplus 40 as a voucher!
the MX Vertical can be used from 3 different PCs, where it has a switch to go between one of 3 PCs, sometimes I run out as I have Windows and Linux on the tower and laptop which equates to 4 PCs, as the mouse pairing is OS level and not hardware level. sometimes I need to run Linux on both, eg I had to compile a Linux program on the M.2 drive to move to the Linux on the other machine.
I just need the wired mouse to pair the wireless one, and also I need the wired mouse for the early startup as that cannot be used with a wireless mouse. The wireless mouse does have an alternative adaptor which is USB, perhaps I can use that, I dont know if it is compatible with the early startup. but I can only install that on one machine. I did keep the wireless adaptor for the replaced one, but I dont know if I can use it with the new one.
And costs 685 quid,
25 kilos!
how would I use it in the UK?
some machines with US power plugs like that arrive with a UK power cable which converts it, but it needs to be designed to accept the UK power which is 230V 50Hz, same as Germany. in the old days the UK was 240V 50Hz, and Germany was 220V 50Hz, then they uniformised that to 230V plus minus 10V and 50Hz so you could use the same equipment in both countries. Germany also uses PAL for TV, but I think the sound is arranged differently, so if you used a dvd recorder in the other country, there might be no sound.
France uses SECAM, I think the russian system is based on SECAM. at uni someone told me the US NTSC is nicknamed "never the same colour" as when there is a disturbance you get crazy colours, whereas with PAL disturbances cause it to go monochrome as the alternating directions cancel out colour distortions.
I need to think over this, if I go for the 685 one, I need to delay it a bit, as I have been spending money like there is no tomorrow! I bought a second hand 3D 3MOS camcorder recently, brand new condition. It has the best video colour I have ever seen, 100% realistic, where it has 6 MOS sensors, 1 for each of r, g, b for each lens. most 3D camcorders just have 1 sensor for all 6! that technology of 1 MOS per r, g, b is called 3MOS by Panasonic. it is old and discontinued technology, so eg it has two large format 64GB SD cards. large also, but for 3D that is best.
Well, i don't necessarily mean that something in the PSU is damaged. After all, you bought one of the best (if not the best) PSU money can buy.
Instead, i think the USB hub just triggered PSU's protections (either OCP, OVP or UVP). Hence why PSU shut the PC down.
Here's more reading about protections inside the PSU: https://www.tomshardware.com/reviews/power-supplies-101,4193-21.html
25 kilos!
Yes, since it's beefy.
Well, you need IEC C14 to UK plug adapter, if you want to use common UK plugs with it,
amazon UK: https://www.amazon.co.uk/Elec-Plug-Socket-Power-Black/dp/B078WV3B4G?crid=1VOZJ2ZU4Y7CK
OR use direct cable that ends with IEC C14 and plugs into UPS'es IEC C13 socket.
Btw, those IEC C-connectors are international/universal ones. E.g if you remove power cable from the behind of any PSU, you'll see the same IEC C13 socket in the PSU, while the cable has IEC C14 plug.
the IEC sockets are what the american houses have on the wall as their power sockets!
the PSUs have those because the main market is america, so they have pushed their wall sockets on the world where now everyone arranges those sockets.
