G gunnerlife.ali8 Sep 23, 2018 1 0 10 Sep 23, 2018 #1 I am transferring data between two laptops using an ethernet cable CAT 5e but the problem is that i am not getting speed higher than 11 MB/s. From what i have heard, i should atleast get more than 50mb per second. Please help me out
Solution kanewolf Sep 23, 2018 If you are getting 11MB/s (megabytes) then that is correct for a 100Mb/s (megabit) network. Many laptops do have only a 100Mbit ethernet port.
kanewolf Titan Moderator May 29, 2013 38,654 3,807 156,790 Sep 23, 2018 Solution #2 If you are getting 11MB/s (megabytes) then that is correct for a 100Mb/s (megabit) network. Many laptops do have only a 100Mbit ethernet port. Upvote 0 Downvote Solution
