[SOLVED] Trident Z RGB lights stay on after boot then turn off
Jan 3, 2019
Whenever I launch my computer my ram led's will turn on for maybe 15 seconds then they will turn off until I launch the g.skill software and turn the led's on. Mainly wondering if there was a way to keep them on the entire time after I boot my pc up instead of having to open the software every time to turn them back on?
it doesn't work for me anymore since i played bo4 and the software messed it up but you can try this: go into bios, select mhz for ram, make it auto. also i'd try updating bios so it will know the auto is what the factory mhz default is.
i have same problem. I have Z390 Taichi mobo and Aorus 1080 Ti. I'm thinking, that i my pc have RGB controll conflict. RAM lights stay on after boot and then turn off. I load XMP profile, i update bios but the problem is not solved.
