Archived from groups: microsoft.public.windowsxp.messenger (
More info?)
I have the revision "B" with the latest firmware which should support UPnP.
MSN says your are connected to the internet through a UPnp IP restricted NAT
(Administrator). Is this what I need?
"Jonathan Kay [MVP]" wrote:
> Hi Ralph,
> No, just opened ports won't make it work; you need Universal Plug and Play (UPnP) support in
> order for audio conversations to consistently be able to be established. The 704P does
> support UPnP, but you will need a firmware update:
> http://support.dlink.com/downloads/
> ____________________________________________
> Jonathan Kay
> Microsoft MVP - Windows Messenger/MSN Messenger
> Associate Expert
> http://www.microsoft.com/windowsxp/expertzone/
> Messenger Resources -
http://messenger.jonathankay.com
> All posts unless otherwise specified are (c) 2004 Jonathan Kay.
> You *must* contact me for redistribution rights.
> "Ralph" <Ralph@discussions.microsoft.com> wrote in message
> news:2C9B2013-A4CD-441F-8FDD-D1BC4D927CAC@microsoft.com...
> >I understand that in a non UPnP I can open ports 5004 - 65535 to receive/send
> > audio. My Dlink 704P router allows me to open those ports with a trigger
> > port when the application launches.
> > Does MSN 6.2 have a trigger port?
> > Is there separate port when you try to initiate an audio conversation?
