Hey!
I took out my gpu to clean the other day, and my PC didnt want to start. It turned on and instantly shut off continously. After an hour of reseating the GPU multiple times, trying different PCI-E slot I determined that the system just refused to turn on with USB peripherials plugged in (ie mouse or dac). Sometimes it would boot, but reinstall gpu drivers? Curiously my gpu started having loud coil whine too, this has not happened until then. Very rarely I hear audible POPs coming from the chassis. Its so random I cant really determine where its coming from, but my guess would be the PSU. Mainly when the system is cold. This is also a new occurance.
Its worth noting my hard drive gave up a few weeks back, so I installed an NVME SSD and took out the hard drive cage.
Example
The case is a Fractal Design Focus G. Could this be a grounding issue? or is my PSU malfunctioning? Its a Seasonic Focus Plus PX750 Platinum. Few month old so its practically new. 2 separate PCI-E cables go to the GPU (2080 Super) and the fans are set to active mode
Right now after booting up just fine once without anything plugged in my pc works "normally" aside from the problems mentioned above. It doesnt matter what fps is set to the coil whine (my guess would be any load above 100W) and the random pop sounds stay.
I have warranty still on every part except the GPU
system specs:
Latest Windows 10 feature update
MSI Z390 Gaming Edge AC
i5 9600k@5Ghz
16GB DDR4 3200mhz ram@3800mhz
MSI 2080 Super Gaming X Trio
Example
system specs:
i5 9600k@5Ghz
