Greetings. For the entire pandemic, my Zoom performance at home has been excellent. Zero problems. Over the past two weeks or so, I have been having problems where the client says "your connection is unstable", the screen freezes, and the connection occasionally drops altogether. This morning I had a 30 minute session where all of the above happened and the connection dropped and reconnected three times.
I just got off the phone with my ISP (Cox) who checked out my modem. My signal levels are good. There are no dropped packets (trying the test 2x). There are no outages in my area. So it looks like the problem is not there.
This leads me to believe the problem could be with my router. It's an ASUS RT-AC68W that is several years old. The machine I just used that had many dropped connections is hardwired to it. It has the latest non-beta firmware (there is a beta available but it requires manual installation and it looks like all it affects is security issues). I have already disabled SIP passthrough, a step recommended by others trying to fix Zoom stability issues.
Is there any additional troubleshooting I can do to determine if the router is the source of the problems?
