J Jamore Pickett Reputable Jun 24, 2015 1 0 4,510 Jun 24, 2015 #1 can anyone help im trying to block facebook and porn sites for anyone using my wifi on my ubee ddw365 from cox. i can only figure out how to block websites for certain devices not all.
Solution Ralston18 Jun 25, 2015 Jamore, Link to the User Manual: http://www.ubeeinteractive.com/sites/default/files/file_resources/DDW365_User_Guide_Cox_0.pdf I think the information you need is mainly in Chapter 8. Should be able to use a combination of keywords, websites, and time access control to block targeted sites. Then plan on changing your wireless network password and do not allow anyone else access until they understand your rules of use. Good luck.
Ralston18 Titan Moderator Oct 11, 2014 39,458 4,405 146,290 Jun 25, 2015 Solution #2 Jamore, Link to the User Manual: http://www.ubeeinteractive.com/sites/default/files/file_resources/DDW365_User_Guide_Cox_0.pdf I think the information you need is mainly in Chapter 8. Should be able to use a combination of keywords, websites, and time access control to block targeted sites. Then plan on changing your wireless network password and do not allow anyone else access until they understand your rules of use. Good luck. Upvote 0 Downvote Solution
