Hey there !
I've a strange behavior with my computer (asus rog strix z270f gaming // Corsair RM850X and others...) I'm used to turn off the power supply for night (or a little orange power indicator is perturbating my sleep.) And everything was all right.
Since few monthes, when I turn on the power supply, then I turn on the computer, the computer AND the power supply suddenly turn off, with a "clac" noise. Then, all is starting, and I've a screen with this message :
I did it, but it didn't solve the issue, moreover : when I turn on the power supply the morning after i did these suggested changes, the issue is still here, AND the parameters in the bios are reset as their was.
Note : I've this issue since a day I was tired and I turned off the power supply while Windows was booting.
I've 2 hypothesis :
1) I caused damages to the power supply (I think so because of the "clac" noise.)
2) The button battery is dead (because of lose of parameters when I turn off the power supply.)
What do you think about it ?
Thanks!
"After setting up Intel(R) Optane Memory or the RAID configuration was built, SATA Mode Selection must be changed to RAID mode to avoid unknown issues. Press F1 to Run SETUP."
I've 2 hypothesis :
Thanks!
