I have the MSI mph Coreliquid D360 AIO and the ASUS ROG Strix X670 E-e gaming WIFI mobo. 1) The first challenge I face is regarding the plugs coming out of the pump. I have installed the fans on top and the pump is installed and now I must figure out how to connect the wiring. The one plug coming from the pump has a tag on it labeled "cpu fan" and it is a 3-pin plug with 2 wires, one in the left hole and one in the right hole with no wire in the middle. The mobo has 3, 4-pin headers at the top labeled AIO pump, CPU OPT, and CPU fan. I cannot find a 3- pin header anywhere on the mobo that this plug could fit. Their schematic makes it look like a four-pin plug. Any ideas here? The SATA plug goes to the PSU, no problem, 2) and the other plug goes to a header they have labeled "JUSB." There are 3, USB 2.0 headers at the bottom of the mobo labeled USB_2425; USB_14_15; and USB_1617. Does it matter which one I use for the pump, or another header altogether different? 3) The third question I have is which ARGB header should I use for the fan lighting? There are 3 addressable gen 2 headers on the mobo. Would one of these be what I need to use here for the AIO ARGB? If not , then what would you suggest? I thank you guys. I just stumbled onto this forum tonight and I am grateful I did. This is my first time to build a computer and I will be 71 in October. I just spent the last 6 & 1/2 years building and flying racing drones. I needed a break from that , so I decided to build a computer. I look forward to your help and if there is anything I can do to help, I will.
