Trying to find a power management utility from intel
sparky952
Hi!
I lost my drivers disk for my 'Gaming' Laptop. When Windows 8 decided to update it somehow managed to corrupt my Linux partition that happened to have Windows boot manager on it so after being corrupted windows 8 or 7 could not boot, I booted a live USB of Zorin to install grub so I could sort Windows's boot-loader out. Re-booted into windows 7, fixed the MBR, and then windows 8 decided not to work and also not to put Zorin in it's boot list. I got fed up and wiped the SSD and re-installed windows 7 and 8 but I could not find my drivers disk.
I now have all my drivers because I used driver pack to re install everything however the software that came with the CD I cannot find. There is a nice piece of software that opened up a power management windows that you could adjust your power settings and see your current power usage, however I have forgotten the name of it. I'm pretty sure it is from Intel, even though Google is not giving me any results... Annoyingly I cannot find the drivers for my specific laptop on Novatech's website.
I have been trying to find it via google but have had no luck, so turned to trusty tom's hardware for help... There is also what looks like a mini lightning bolt on my F4 key that also opens the program up.
Really annoying as I quite liked this software because it was brilliant for battery life!
Thanks for the help. :)
Lappy: Novatech Nspire 1593 that has been customised
Lappy on Novatech's website
Os: Win 7, Win 8, Zorin OS (On external SSD)
Processor: i7-4712MQ
Grapics: Nvidia GeForce GT745
All drivers have been updated, It's just the utilities I cannot find! (Found Photkey only)
If you need any more Info just say, sorry for if this is in the wrong section... (Only ever made two posts here!)
Only drivers I could really find...
Thanks a lot, I will try later! If I do get a replacement I'll set your answer as the solution!
Thanks, pity you did not know what the software is called 🙁
