I am trying to do the following:
I found a Dell 24" 5490 AIO i5 with onboard intel graphics
I installed a 4x4 m.2 mkey lexar NM790 2280 form factor (as there is space, just nothing to bolt it down)
Its in a 32Gbps slot (m.2 PCIe 3.0)
I wanted to upgrade the MBoard to get the MBoard with the 2GB GDDR5 Nvidia graphics, because I want to run Fooocus software for AI image generation.
Searching this, it is possible, would be slow, and needs some work around... so...
I can spend $AU393 on this MB or... get external with an external graphics - It may be needed anyway, but alone could fail (see why later).
With external Nvida Graphics, I would want to spend about $Nvidia 1660 ~ $Nvidia 3060 (MAX!), as that's a AU$200-$400 price range for new card, the internal would suck and cost about the same all up to buy as its motherboard mounted.
I discovered I have another PCI slot, the A/E keyed slot for my wifi/bt module - so I set about learning all the stuff about the less talked about A/E or A+E key slot that may or may not be PCI 3.0 too (see dell manual's - always so clear).
I can get an external video adapter that claims it will provide full Gbps that pci 3.0 GPU slots use... but, and its more of a big 'BUT'... I read that I may use all the PCI slots with the current NVME (Lexar SSD mentioned above) and end up with my NVME SSD using the full 3.0 x16 lanes, and I read that I will possibly be stuck with x1 lane on the wifi (A/E) slot for the NVME if i install it using an adapter (as the adapters all say 'only access to x1 lane')
if I put my NVME SSD (using an Mkey / A+E key adapter) in the A/E slot (from other users and hardware feedback) I may only get 1x lane or between 550-800MB per sec read and write speed vs my current 3480 Read/3460 Write speeds
Now I am also told in other forums that the A/E key slot will give me 2.5Gbps, Dell specs seem to show I have 2 wifi card options on that pc.
I searched them, both are A/E key slot factor, one is slow (which iIhave) and the other, (thanks intel specs) hits 2.4Gbps (which is on par with the speed others claim, despite if that is wifi or internal transfer speeds to the motherboard from the card).
8gbps, down to 2.4, for graphics, could suck... but I am trying to work out if the signal back and forth is just delivering the 'do this' data, and 'processed' data being returned - ie pictures for my internal graphics to display, or AI work that's processed.
If 2.4Gbps is all I get, and hoping that i don't get PCI x1 speeds for the graphics, I assume that I could then even game a little.
The onboard NVIDIA (if I upgrade) may not cut it to do AI work, there are work arounds that may enable it, but the drivers from the upgrade apparently will assist the chance of clashes when I get an external card (ie the onboard intel trying to talk to an external NVIDIA could clash, which I also heard happen when using differing graphics cards). Nvidia is required to run the software so I have to get a GTX/RTX of 4 or 6GB plus.
I am hoping that, as I have a HDD on the SATA (which was just to transfer from the old samsung SSD to the new NVME), if I remove the SATA HDD, I could gain 1x PCI lane.
I plan to get a USB wifi/bluetooth and an adapter for putting the NVME into the A/E key as I may need to swap the SSD and Graphics around to look at performance for configurations.
I plan to buy 2 adapter cables for the external card slot one being the A/E key to PCI 3.0, the other to be M key to PCI 3.0.
this way i can put the NVME into the A/E key slot if the graphics do much better in the M.2 Mkey slot or vice a versa if the graphics doesn't show too much loss in the A/E
But... i could save a ton of time and money if someone more up to date can assist me!
