Hi
Recently my laptop hardrive (a 4TB 2.5" Seagate something something) stopped working. I googled and youtubed the sounds from it,and it may be stuck motor in the middle of the discs. I am going to try to manually reset it,to see if i can save all the data (or what i can) from it.
The problem:
The case for this harddrive have multiple screws being used for the lid.
-Torx T5
-Torx T6
-Pentalobe? (5 star pattern,see picture. But what size? I have Pentalobe for my old Iphones,but they are way to small.
Thank you for your feedback.
The problem:
-Torx T5
-Torx T6
