As process technologies get more sophisticated, TSMC charges more for wafers.
TSMC Expected to Charge $25,000 per 2nm Wafer : Read more
BTW a 300 mm wafer gives 500cm2 of chips for 5 dollars per cm2. the die on an apple chip is 1.2 cm2. What's the maths on the transistor cost? 5 squared is 25 and 2 squared is 4, so you get i.e. 3-4 times more transistors for the same surface area, at twice the price.So more expensive GPUs and CPUs in the future. Quite expected…
Interesting. About douple the price of 5nm at 2022.
Just buy discounted systems or parts. Every CPU from the latest and previous gens is discounted, 5-10 year old CPUs are often perfectly fine, and other components such as DRAM and SSDs have fallen in price precipitously. GPU pricing is still elevated but getting good 1080p performance is fairly cheap, e.g. as low as 180 USD for RX 6600 right now and Phoenix APUs probably coming to AM5 soon.Alright, I'm done with computers. I'll think I'll take up surfing or something...
Now that we have practically reached the end of the road for conventional silicon short of stacking transistors, performance is about to become a direct function of how much money you are willing to spend on a CPU/GPU chip package. The only performance per dollar improvements we'll see will be coming directly out of manufacturers' profit margins.If the hobby gets really bad again, it will be because of another catastrophic global event, not an 80% rise in bleeding edge wafer costs.
We should give monolithic 3D processors built using chemical vapor deposition, nanotubes, etc. a decade to materialize before we go full doom and gloom.Now that we have practically reached the end of the road for conventional silicon short of stacking transistors, performance is about to become a direct function of how much money you are willing to spend on a CPU/GPU chip package. The only performance per dollar improvements we'll see will be coming directly out of manufacturers' profit margins.
No, both the width and the hight (x and y) of the process needs to be 50% smaller for the number to increase by 400% that's not how process nm numbers work, they often don't correspond to any physical size at all and are just an representation of how much better the node is.if the process width is 50% smaller, then the number of transistors per wafer is 400% higher, and the price is going up by 200%.
N3 technology will offer up to 70% logic density gain, up to 15% speed improvement at the same power and up to 30% power reduction at the same speed as compared with N5 technology.
It's not about making things smaller, that is not what makes a CPU faster, if you need more cores or wider cores on a CPU you can do that no matter the size, well...within reason. It makes your dies larger but that is not the problem, we have all seen the pics of humongous server CPUs.well anyways, in just a few generations, we will hit a wall : it will not be physically possible to further reduce the size of the electric paths. I have read somewhere that right now the electric circuits inside a modern CPU are only distanced by 20 atoms from each other. there is not much more to trim before to encounter quantic effects between the paths.
But the same chip would take up much less space at 2nm compared to 5nm, so you'd get more yield per wafer?So more expensive GPUs and CPUs in the future. Quite expected…
Maybe 20% in total cost of GPUs, but almost full towards the CPUs.
It's clickbait, this site is getting bad about it. I was thinking last night about how much the quality of content has gone down since the early 2000s.This article misses the point completely.
N5 price is $13500/300mm
N2 price is $24000/300mm
(2/5)^2 = 0.16
0.16*$24000 = $3840
Prices are going way down per area.
That math only works if process node names scaled linearly with actual feature sizes. The reality is that some dimensions are coming down much slower. For example, "minimum metal pitch" has only come down from 64nm to 24nm between TSMC's 16nm and 3nm nodes. The node name suggests a 5X increase in dimensional density while that part of the actual process only scales half as much.This article misses the point completely.
(2/5)^2 = 0.16
0.16*$24000 = $3840
