Background
I have had this system for a while, and I recently changed the motherboard for the same model and added more RAM. The computer was working fine (I usually never turn off the system), and I had no issues with it until I updated the Nvidia driver to version 496.76. It asked me to restart the computer, but then it wouldn’t turn on.
Troubleshooting
Here is what I have tried so far:
None of these steps worked. When I try to turn on the computer, there is no response at all. No beeps, no lights, no fans, no error messages. It’s like the power button is dead.
Specs
These are my PC specs:
TUF GAMING X570-PRO WIFI II
Ryzen 5 3600
Corsair LPX DDR4 3600MHz RAM (2x32GB)
H110i AIO
RTX 2070 Super
XFX 80Plus Gold 650W PSU
2x M.2 NVMe SSDs (Corsair, I think)
Help
Does anyone have any idea what could be causing this problem? I would appreciate any advice or suggestions on how to fix this issue. Thank you.
Troubleshooting
- Swapping RAM to other slots
- Trying one stick per slot
- BIOS flashback (I used a USB flash drive with the latest BIOS file and pressed the flashback button on the motherboard)
- Turning on without GPU
- Resetting the CPU
- Turning on without AIO (the CPU got hot, which means there was some voltage going through)
- Removing the battery
- Clearing CMOS
- Checking for bent pins
- Reseating the 24 and 2x8 pins cables
- Leaving it on for some time
- Leaving it off for some more time
Specs
Ryzen 5 3600
H110i AIO
RTX 2070 Super
Help
