TurboBoost need cooler or no ?
Sudeep Chavan
96
I will buy i5 4690k
If i turbo boost the CPU do i need after market cooler or no
otherwise i will get Cooler Master Hyper TX3
i will be not overclocking it till 4.6Ghz
i will just overclock to 3.9Ghz
Will Stock cooler maintains Temp
Available from 3 sellers.
http://www.amazon.in/gp/offer-listing/B005O65JXI/ref=dp_olp_0?ie=UTF8&condition=all&sr=8-1&qid=1430926891
Also the Hyper 212x appears to be the newer version of the Hyper...
the stock cooler can handle turbo boost, might get loud on load. however, if you manually overclock your 4690k, you might wanna opt for a 3rd party cooler for better noise and heat dissipation performance. hyper tx3 is okay for stock performance and minor o.c. but not for high o.c.
edit:
Cooler Master: Hyper TX3
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-tx3/
Cooler Master: Hyper TX3 EVO
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-tx3-evo/
both support socket 1150
i will never cross more than 3.9Ghz
the stock cooler might get quite loud on load. if you find the noise unbearable, an after market cooler will give you quieter operation as well as better thermal performance.
in my personal opinion, get the TX3, it'll be better regardless. if you're budget-limited, try out the stock cooler first, since you're saying that you'd never cross 3.9 GHz.
edit: getting a 3rd party cooler alone isn't enough. you're case should be good enough to exhaust the heated air outside.
Out of stock where? The internet is vast and the places to buy things from is numerous. The Hyper 212 Evo is in stock at Amazon and Newegg. Unless you live in a remote African village where your supply of goods is from the mud hut down the road, I'm sure you can get it from somewhere.
The stock cooler is good enough for 3.9Ghz, as that is the default boost speed, before I overclocked I turned off turbo boost and put it to a 39x multiplier, it made no difference in temps at all, I'm using the hyper 212 but it will be the same. If you're not going higher than 3.9Ghz, you don't need an aftermarket cooler.
So send me link from Snapdeal or from amazon.in or from flipkart
I will try with stock cooler what is the normal temp and max temp of CPU
In India we will not get
Using the stock cooler? Around 70c while gaming, the max I'd run mine at is 70c.
70c is not so high if it goes above 70c i will buy aftermarket cooler
Going above 70c is okay if you're stress testing it (Maybe 80c-85c as a max while stress testing), but if it's going over 70c while gaming, you should get an aftermarket cooler.
what is your room/ambient temperature? the temperature delta is more important.
running at 70c with ambient temp at 20-25c has a 50-45c delta. if the room temp is at 35-40c or higher (e.g. in summer in india), that load temp will become 85-90c, and will drive the fan rpm and noise emission to the maximum.
my room temperature will be 15-25c
Instead of that better i will take TX3 or 212x
i will get Corsair 400R cabinet and ASRock Fatal1ty Z97x killer and i5 4690k and seasonic 850 watt PSU are this compatible
