Hey guys!
I would like to ask for help regarding my TV - Samsung UE55KU6172 settings.
My setup is PC->HDMI->TV.
The TV has 3 HDMI ports: HDMI 1/DVI, HDMI 2 and HDMI 3 (ARC).
When I plug the cable into either 2 or 3, I have display and it works fine - I can set 4096x2160 or 3840x2160 (shows as recommended so I use it).And what is most important, I can select 60hz frequency - at 30hz it is just terrible, a sore for the eyes
So far I have therefore been using this (HDMI2/3).
However, now I tried the HDMI1/DVI slot and it seems to "unlock" new options such as UHD, etc. However, the resolution offered is only 4096x2160 and only at 30hz - unplayable, uncontrollable. And when I try to enable the UHD option in windows/change resolution to any other, I get a black screen and in a while it seems to cancel the option and then the display is back but UHD is not enabled.
Could anyone please try to explain why this is happening, if it is "normal" and possibly recommend me the best settings to set on the PC/TV to get the most out of the TV? My GPU is MSI GTX 1070ti - I just bought it to get the most out of the new TV...
Oh and a second thing - the information about my display in windows say Bit depth 8bit and standard dynamic range SDR - but I read somewhere the TV should be capable of much more?
Thanks a ton!!
George
Thanks a ton!!
George
