I use a tv as a monitor an LG FLATRON M2380A, it has a VGA and an HDMI port. Untill recently i connected the motherboard and the screen via a VGA cable, it looked fine. Now i have a GPU with HDMI and DVI ports, I connected the GPU and screen via HDMI. Turns out tvs are configured in a weird way that you have to change the name of the HDMI to "PC" in the tv options, otherwise it will look "weird". Most smart tvs can do this, mine can't.
So, what can i do? I know there is no damage in the tv, video card, and cables. Its just the weird way tvs are configured. I tried to find "pc drivers" for my display and found some files from LG, but windows insists that it already has the best drivers installed, and couldn´t get it to recognize what i downloaded as an option.
HELP
Examples of the weird input thing:
VGA
HDMI
(these are not from my pc. They are from someone who had the input problem, but solved it changing the name with options from within the tv that i don´t have)
Windows10 home
LG FLATRON M2380A
HD 7870 ghz editon
GA-H61M-DS2 (rev2.2)
HELP
VGA
HDMI
Windows10 home
LG FLATRON M2380A
HD 7870 ghz editon
