S stevehendo34 Mar 23, 2019 14 0 10 Dec 7, 2019 #1 My Tuf x570 motherboard has two cpu/apx connectors, one 8 pin one 4 pin on the mother board. They rite next to each other. My EVGA power supply has to CPU outputs also, CPU1 and CPU2. Do I put power to both the motherboard ATX plugs 8 and 4 pin?
Solution Dark Lord of Tech Dec 7, 2019 They board will usually run with just the one 8 pin , but you can populate both with no issues.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,760 1,840 159,590 Dec 7, 2019 Solution #2 They board will usually run with just the one 8 pin , but you can populate both with no issues. Upvote 0 Downvote Solution
