Two Crossfire SAPPHIRE Radeon RX 560 2GB Dual 4k Monitor Support
drocksixers
I'm thinking about upgrading my monitor setup and I was wondering if dual SAPPHIRE Radeon RX 560 2GB in Crossfire would be able to support two 4k (3840 x 2160) monitors via DisplayPort. I'm not sure if I am understanding the Maximum Resolution specification correctly. On a single card, the maximum resolution is 3840 x 2160. Does this mean that if I put two of these cards in Crossfire that if I plug in each 4k monitor into each of the cards that each will have the full 3840 x 2160 resolution? Would this setup also allow me to play Overwatch on one 4k monitor at 4k resolution at reasonable FPS?
if it is for windows only tasks a single 560 can do two 4k displays by itself easily
for gaming a rx 560 is only able to handle a single...
for gaming a rx 560 is only able to handle a single 1080p screen with decent fps,
multi screen 4k... you are asking a baby to lift 600 pounds it just does NOT have the power
for gaming on multiple 4k displays you would need at least two 1080 ti in sli
