I tried to keep it to a minimum, but this post has a lot of detail.
I have a two Dells -
1. XPS 420, Q6600, from 2007
2. Slim Line 540s, Q8399, from 2009
This part applies to both computers:
1. Neither will power on at all
2. The 420 showed signs of impending PSU failure prior to poofing - self reboots. The 540 did not
3. Both passed the manual multimeter power supply test - fan came on and all voltages at all active pins on the 24 pin connector are correct.
QUESTION 1: Is this a comprehensive test for the PSU? I've read that one of the other connectors must also be tested for voltage.
QUESTION 2: Are the other connectors from the PSU (such as the power to the HDD's) inactive until the PC passes POST?
My research yielded conflicting info, but the same general message: Bad motherboard, bad switch assembly, or bad front panel I/O assembly. Information overload and unclear terminology. "Computer won't boot" could mean different things, different points of the entire process, and often is not specified in postsJust weird that both machines have the same problem, within weeks of each other. But, for now, I'm just focusing on the 420 as things are easier to ge to. Here's what I see now:
1. Continuity check of connector coming from front panel shows the switch itself works.
2. There is an LED on the motherboard that lights and stays on
3. Another weird thing. That connector appears to have pin holes, but so does the corresponding port/connector on the MB. No pins anywhere to be found.
QUESTION 3: Is it possible the pins all came off when I disconnected this connector from the MB? There are no traces of pins or evidence they ever existed - 0r that it somehow doesnt use pins at all?
QUESTION 4: Where might I find a diagram that tells me what the other pins are for on this connector an what do I test for? The manual does not supply this info. (If I could determine which pins on the MB side were for the switch, I could jump those).
QUESTION 5: There were other "solutions" I came across, but the just didn't seem likely. Clearing the CMOS by jumper or removing the batter, replacing the bettery itself, or cooking the video card (reflow). Also something about the ribbon cable.
Sorry for all this detail - anyone kind enough to help out, please don't feel obligated to tackle all the questions. Amy input is appreciated. And I am aware that I really just need a new computer but just can't afford it now. I've always had better longevity with Dell's - I'm using a Pentium D tower now, and it's been going strong for over a decade.
