[SOLVED] Two exact same GPU cards but major difference in GPU Clock ?
Oct 21, 2021
21
I bought two Palit 3080 Ti GamingPro cards from the same store.
The first one gave me good performance @60% tdp I get upto 1330mhz gpu clock(and it looks like it auto just in gpu-z), 1327.7mhz memory clock
the second one @60% tdp I get 450mhz ~ 550mhz(this one doesn't auto adjust it is just flat all the way), 1327.7mhz memory clock.
I tried msi afterburner to change each settings but setting the 3080ti affects both cards ( Is there a way to set oc for each 3080ti in afterburner? )
I am literally lost right now because clearly I am missing some very important settings here... there is no way two exact same gpu have this huge amount of difference.
first 3080ti
View: https://imgur.com/a/bhtVJDK
second 3080ti
View: https://imgur.com/a/S2lb3VU
Hi, I managed to solve this. Apparently it has something to do with silicon lottery thingy. I managed to make them mine at the same hashrate by upping my 2nd gpu's tdp by 3~5%
