D dis236 Reputable Apr 17, 2014 33 0 4,540 Apr 17, 2014 #1 Hi, I own a Gigabyte hd7870 oc edition graphics card and they come with two six pin power port however my psu has only one six pin cable. Is it okay if I run it with only one?
Solution bignastyid Apr 17, 2014 It requires both. Usually they won't run at all with just one. Not having enough connectors is usually a sign the psu need to be replaced.
bignastyid Titan Moderator Jun 19, 2011 33,535 1,635 159,590 Apr 17, 2014 Solution #2 It requires both. Usually they won't run at all with just one. Not having enough connectors is usually a sign the psu need to be replaced. Upvote 0 Downvote Solution
DeadRam Distinguished Jun 14, 2007 557 0 19,160 Apr 17, 2014 #3 The video card should have come with adapters that convert two 4 pin Molex connectors to one 6 pin PCie power connector. Upvote 1 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Apr 17, 2014 #4 Or if the PSU is big enough you can use a molex to PCIe adapter for the second connection, often included with the card. Upvote 0 Downvote
D dis236 Reputable Apr 17, 2014 33 0 4,540 Apr 17, 2014 #5 Thx a lot It's working properly now Upvote 0 Downvote
